Hi all,
Any advice about fitting a new exhaust manifold gasket and perhaps down-pipe, if just refitting manifold gasket, can you do it without removing the sub-frame ? thanks in advance
So guys I have a 2009 Clio Sport, it has 5 wheel nuts per weel, how do I know if it is a 197 os 200 bhp (appoligies, this is my daughters car, I am doing the donkey work !!)
are you changing the manifold or just the gasket? I assume the manifold is blowing from the flexi joint so needs a new full manifold (or yours repaired once removed)? its a pig of a job and a common issue.
