Greeny.
								440i + 182
				I was always under the impression that having abit of rake was the best option but that is purely based on reading up on here in the past, however if that’s the case why do the Mk2 Cup Racers have their rear ends so low? Honestly just interested more than anything. At present my front end is currently 10mm lower than the rear, I can get 5mm off the rear if I remove the shim, just need to check the rear spring doesn’t fall out when it’s jacked up, this is on BC BR Coilovers.
Also what’s everyone’s opinion dampening wise front/rear, I generally set everything to full hard, purely because I don’t know any better if im honest although its never 'caused' me an issue, not that and I dont know any better.
Ta,
Dan
Ta,
Dan
