benji93
  ph2 182, mk1 mx5
Res decat fitted and a new manifold flange welded on (as the last one was disappearing) at the weekend
Sent from my SM-G950F using Tapatalk
Clio_fool
Had 2 PS 3's fitted on the front after getting a puncture the other night. While I had the front in the air I raised the suspension 10mm and refitted the arch liner. Cheapo coilover covers done a good job so far, threads were lovely and clean?. Fitted new headlamps last weekend too. I think that's enough spannering for a couple of years now!
td_dan
  Clio DCi
Had a busy weekend in general.
The daily dci got some love.
  1. Full 172 front running gear
  2. Removed 172k oil burner
  3. Fitted 90k engine with new waterpump and cambelt
  4. Plated up the sunroof as couldnt be bothered sorting the leaks
Just got to change the rear shoes, bleed the fronts and get the tracking done as its quite far out due new inner and outer track rods.
  Z34 370z Nismo
Spend a load of money on the old girl, Got the good folks down at two tecs to do a cambelt/defaser pulley/waterpump/aux belt change while I Spent best part of the day taking in the sights of Dartford...?
  Z34 370z Nismo
Next time, get the bus into Bluewater. Better than wandering the hard streets of Shartford.....
Ye me and wife ended up getting bus to bluewater. Had a day at blue water, was worth it though. Car feels like new.
? Just need to sort out my farting exhaust and it'll be wonderful.
  PH2 172
Ph 2 non cup 172 .
Finally got round to fitting the new OE rear discs, handbrake cables (182), brake pipes & Ridex rear calipers ( less hassle than rebuilding the originals ) I have
accumulated over the last 4 weeks, along with HEL braided lines to replace the short rear flexi`s. & some new pads.
I had to crank up the 2 nuts on the adjuster rod of the hand brake lever as there is a fractional difference in the inner /outer lengths between 172 & 182 cables
to get a decent hand brake lever.
Job done, reckon I can forget any issues in this area in the foreseeable future.
  • 18-11-22 New LH rear OE disc, brake pipe, cable & Ridex caliper 133430 miles.jpg
  • 18-11-22 New RH rear OE disc, brake pipe, cable & Ridex caliper 13430 miles.jpg
Krarl
Changed the mani-cat on my Mrs’ car. Started at 3pm and finished by 6pm! Result!
Everything on a Peugeot 107 is so easy!!
The old one was a little bit worse for wear...
I blame Toyota for using w**k steel, it’s an 07 plate car with 86k. You’d think it was 30 year old by the amount of rot on it
DomP182
  ph1 172, Arctic182
Replaced the chipped and peeling door trims and bullets on my project flamer.
Has anyone else found they rub through the paint where they touch? Very tiny bit of rust developing where it has so open to suggestions on what to do to halt it.
boomerbang2006
  clio 172,2001
Had a small fuel leak on the injector rail feed pipe,have managed to bypass the split with a temporary fix..New fuel pipe ordered getting it fitted on tuesday.
  Clio Tourer TCE100
Switched from summer (toyo proxes) to winter rubber (avon ice touring) - not that we ever get blizzards in the Midlands!
