donnylad
Another place to try for bolts is Williams fasteners, although they have a £2 minimum pick line. To cover this I just buy 2 quids worth of each and save them.
A bit of acf on the self colour bolts makes the last for months
Black oxide bolts won't last a weekend before they're corroded on mine.
OEM's use 10.9's instead of 12.9s if they can because they don't suffer as much from stress corrosion cracking, but they're still all zinc plated.
I tend to steer away from any off the shelf zinc coated bolts for any highly loaded bolts.. they are normally not de-embrittled, which leads to the Zincing process reducing the grade of the fixing.. Hence why no OEM or top end Motorsport team use them
I put these bolts on the subframe support arm from this picture about 7 months ago, acf does wonders. I give the tres and shocks a coating every so often too.
@Nafoff Couldnt say on bulk but ebay seems to best just for a can
https://www.ebay.co.uk/itm/ACF50-Anti-Corrosion-Spray-Rust-Prevention-Protection-Bike-Motorcycle-ACF-50/141212123168?ssPageName=STRK:MEBIDX:IT&_trksid=p2060353.m2749.l2648
I used ACF-50 on the self coloured socket cap bolts on my bucket seat sidemounts, they had started to get surface rust after only a week into being fitted! Just wiped a bit over the head and they still look like new.
My whole car has been sat in my garage for months and not had an issue.
Spray the heads with clear coat? Gonna try this, leave a bolt in the rain to see if it holds up
Got enough to do the whole of cs's cars there [emoji23]
That’s just what I was thinking [emoji6]
I know the bolts as I had to replace mine. I had a chew on locating them as they don’t list them on the parts catalog next to the shaft - see screenshot.Great thread, very useful.
There's a bolt I'm after that I can't see listed, but maybe I'm just not looking properly!
The 182 offside driveshaft has a jointed 'carrier' that bolts to the engine block with three bolts.
I've lost one. (Dickhead!)
They are an odd bolt as they have an unthreaded shoulder under the head, which is slightly larger diameter than the thread itself.
I've e-mailed @renaultpartsdirect and am waiting for a reply, but just spotted this thread and thought maybe @Tomotek might know the part number.
I can post pics tomorrow if that helps
Many thanks,
Andy
Go to Partsouq , stick your Chassis number in or model code If you don’t have chassis number to hand - 182 FF with Cup packs are CB22 - then select engine, transmission etc and you’ll find detailed illustrations with part numbers for your car![]()
I’ve got some of those you can have. Drop me an email at jonwright@mac.com and I’ll send you someWhat a great site, many thanks for that.......although I'm still struggling!
The nearest thing I can find is this
The bolt I need looks like 7 (see photo below), but it has a very weird description 'SCR-RELAY-BRG MTG', and when you click on the part number it says nothing found!
The other bolts, 9 and 6, sound right M8 and 25mm long, but don't have the enlarged shoulder under the head which matches the holes in the driveshaft carrier.
If I use a straight M8 bolt it will be loose in the hole, as the 'shoulder' is 10mm diameter.
This is a picture of the bolt:
The thread is M8, not sure of the pitch, but probably 125
The overall shank length is 28mm
The threaded length is 20mm
The enlarged part of the shank is 10mm diameter and 8mm long.
Question is, where can I get one, or maybe ten just to be safe!
HELP PLEASE!!!!
I can post pics of the driveshaft, carrier and holes in the block if that's any help.
Ta, Andy
Many thanks indeed Jon, very good of you.I’ve got some of those you can have. Drop me an email at jonwright@mac.com and I’ll send you some![]()
Scratch that idea. Wrong sizeMany thanks indeed Jon, very good of you.
@banhama
Have a search on google not on that site. Id give these people a ring first to make sure, or just call renault.
Renault 8201013040 BOLT
Shipped Worldwide! Discounted genuine Renault 8201013040 BOLT and every other available Renault genuine part! allcarpartsfast.co.uk delivers anywhere.www.allcarpartsfast.co.uk
No problem, did you check with them? I called them a while back and they said they couldnt get the part anymore. It was a bit more niche than bolts thoughMany thanks for this @ZachB
I've ordered 3 new bolts.
Foolishly I didn't heed your advice, and just ordered them online!No problem, did you check with them? I called them a while back and they said they couldnt get the part anymore. It was a bit more niche than bolts though
Hopefully it’s fine mate. You could always give Renault themselves a callFoolishly I didn't heed your advice, and just ordered them online!
No communication as yet to say if they are on the way, so I might have to do some chasing
Falcon Workshop Supplies on Ebay for bolts. Worst company i've ever dealt with. Avoid like the plague. Cromwell are superb.View attachment 1504567
