Volvo 360 Daily
leeds_182
North Yorkshire & Humber
One of my favourite parts about the 300 series is the way the bonnet opens.
Also stuck my oem floor mats in that @bashracing found me.
leeds_182
Oil and filter and air filter change. Had 25 mins trying to get the oil filter off but other than that it was quite smooth.
You've got two garages? That's good going.
I so want one of these, I am seriously feeling the need for some old-school RWD action - and, after all, the missus has said that she wants a 4-door car so kids are easier to kart around...
leeds_182
Was also tempted to buy this 940 as a donor for an engine swap to the 360 but looks a little more involved than I thought.
BashRacing
Easiest way would be a low boost turbo set up on your engine by fitting a blow through carb or converting your carb to blow through,
I think your engine is a b19a with a comp ratio of 8.5 so you could get away without an intercooler up to around 0.5 bar of boost
camshaft is 10.5mm of lift with fairly short duration so that would suit a turbo too.
get it done !
cat171
Just thinking, can you remove the GLS badge from the front grille ? I reckon it would look better without it ?
cat171
Not with those wheels on it you ain't mate!! ? Just messin!! I think the clean look from removing it would look great.
The dog doesn’t think much of it by the looks of things.
I keep coming in here expecting a “sold it” post.
