What vice do you have?
Been out buying tools today
1411137
Thought I'd show why I needed a bigger vice...
1411778
1411779
1411780
Here's the new ones next to it
1411781
I'll just grind a channel into it and weld it back together? Itll have to be demoted to another bench though as big Bertha needs to be front and centre
I rubbed mine down to the original paint and then painted it with black hammerite. Wish I'd have just left it original, looks worse now than before haha.
Ouch, usually happens when it's not torqued enough so the shock goes through the front jaw instead of the rear.
Wooden bench doesn't help though, put a steel plate over the edge of the bench and then bolt down through it to support the throat.
That chequer playe will be going on top and I've got steel to line the full bench because we can just leave the welder earth clampe on the end so we never forget? Just have to remember to turn the f**king gas on now?‍♂️??
Every time I see this thread, I think it’s about guilty pleasures.
Now you know why I have steel benches :D
Welder gets earthed to a leg and just slap s**t on top :D
You need your mental state checking then mate?
Yep, the amount of wire I've gone through over the years because I've forgotten to put the pissing earth on??
