Hoses for Brembo Conversion
Oddesy
Car  172 Cup, FK2 Type R
Just sourcing all the parts for the Brembo conversion on my 172 Cup, looking at braided lines, I'm assuming I'll have to buy 197 hoses for the front, but will the rears from that kit fit my car or will I have to buy fronts for a 197 and rear for a 172/182?
Cheers!
I take it yours is a mk2 Clio? If so you will need lines making up. Mk2 end to 197 the other end on one line. Goodridge made my conversion lines. Only for front... rears is mk2 lines as there’s no need to change the rear caliper. Unless you really want 197 rear calipers...not sure if anyone makes a spacer for the rears?
Does anyone know what's the size for the Brembo caliper brake hose fitting ?
I am trying to make some custom Hel brake lines, but I don't know the fitting size for the brembo caliper ( from a Clio 197 / Megane 225 ).
Is it Banjo M8, M10 / 3/8" , M11 / 7/16" or M12 ?
I suppose the fitting angle is straight, right ?
M10 and a 15-30deg angle helps
Bump!
So I have a pair of 197 calipers and need the hoses to fit my 182. As far as I'm aware the braided kit for the 197 will fit? Something like the one kam sells here:
Only the front hoses (REN-115-F)
I'm about to place an order and wanted to be sure thanks!
Digging up an old thread! does anyone know what length theyre meant to be? I bought these ones and they much too long:
lines
I just cable tied the extra length to the shock with a bit of fuel hose round it
Not had any issues and the cars done 7 trackdays and about 6000 miles
Good to know, ive reached out to them to see what they say, but it sounds like they are just overlength and this isnt a mistake on my order.
Still got some time before the builds finished so I might change them for some better fitting ones if they offer a refund.
They've offered to let me return them and replace for a length of my chosing... trying to work out if i can be bothered to take them off and work out the correct length.
