wideband Lambda bluetooth
I think I kinda see the point? but then I kinda don't
Instead of installing a 52mm AFR gauge you now install this and an app, then use you phone to display the same information that you would have got on the gauge?
You could maybe do some logging, but if it doesn't also capture rpm and other data it's not giving you much useful information.
How will Torque read the data though?
Torque pulls most info from the ECU, and that thing is sending it's data over bluetooth to the proprietary app.
