172 heater
DomP182
  ph1 172, Arctic182
While servicing my car I double checked by Googling which way around the cabin filter goes but noticed all the photos are different to mine. The big plug is just lying loose rather than clipped into the heater blower where there is no clip to hold it, there also an open socket with corroded pins on the blower unit itself.
Could it have been replaced with the wrong unit?
  182 clio
Any pictures
DomP182
  ph1 172, Arctic182
DomP182
  ph1 172, Arctic182
The fans all work as they should and the temperature just not the air con
DomP182
  ph1 172, Arctic182
It is odd, the pins are pretty damn corroded on the heater resistor so I cant imagine them cleaning up. All the fan speeds work and the warm air is controllable just no ac
  182 clio
Here's a picture of 182 top box striped
As you can see that goes the left hole so is facing upwards.
Yours seem to go in side ways with no plug connected
DomP182
  ph1 172, Arctic182
It's an early ph2 172 so could it be that they came slightly differently?
DomP182
  ph1 172, Arctic182
But everything works heat wise and all fan speeds work so that suggests the heater resistor is working somehow doesnt it?
  182 clio
Not sure.
The resistor I'm sure has to do with keeping a constant heat. So if set at say 19c it should adjust between hot and cold to keep it at 19c.
Also they are common for stopping the blowers from working so maybe someone has bypassed that part just a guess though.
Tbh this has me scratching my head.
If it's been bypassed that could be the reason you have no Aircon.
Top dash off and trace the wire from heater box to inside would be my suggestion.
DomP182
  ph1 172, Arctic182
The aircon is because the system has no pressure in it but the climate control seems to work fine. I thought someone else might be able shed some light on it, Renaults hey, always entertaining!
  182 clio
Yeah I replaced condenser dryer and pipes to bulk head seems to have done the trick think it cost about 20 used good condition though new o rings regas
DomP182
  ph1 172, Arctic182
By this I mean anything warm works
DomP182
  ph1 172, Arctic182
Had a bit of a dig around today and found this plug too, what's going on with this lot then? Where should it plug in?
MRBILLYUK
  FF Jeden Osiem Dwa
Yours looks to have all the right bits but just looks an untidy mess. I changed my 182's pollen filter a couple of days ago and this is what mine looks like.
DomP182
  ph1 172, Arctic182
Mines a 172 so a bit of a different setup I believe, different plugs by comparison
