Disconnect door wiring loom.
Dex90
Car  11Megne250/02Clio172
Struggling to disconnect door from wiring loom. Found 2 bolts on the outside that I've removed but still doesn't disconnect? Anyone know?
Sent from my COR-L29 using Tapatalk
Pretty sure there is a clip at the top of the plug you pull up to release the plug. No bolts. It's a little while since I have done it. Same as the ECU plug.
Will give it another go tommorow. Cheers
Awesome, cheers. Hard to see with everything in the way blocking view
Similar principle to this.
Is that the door? If so it's the other end you need to disconnect from the Pillar.
Can't pull rubber off to see it?
Doh, the plastic surround pulls off
It's not obvious like every other clip, usually different color the thing you pull or push
Better pic for anyone stuck in the future
