I decided to put some sound deadening behind the rear speakers....this is what I found..
After a bit of sanding it didn't seem too bad..I noticed the whole panel was full of condensation,so hopefully it's rusting from the inside..( I unblocked the drain holes with a cocktail stick will leave it in while treating) ..After this I went into panic mode and checked the whole car....I actually checked under the car last winter it all looked ok,so I'm surprised on what I have found....I have bought this Bilt Hamber stuff...
i was expecting rust at the back of the petrol cap(never looked before) but it looks ok...
I will be coating it just incase.. I'm not looking forward to hours under the car cleaning,sanding,treating and waxing everything in sight,I also found rust forming round the Exhaust/Cat connections ,a good wiring brushing and hammerite krurust seems to have cured that..I plan to paint the area with Rust-Oleum stove and BBQ paint and see if it isn't burnt off..
Anyway sorry bore you all but hopefully I have found it in time...
