Little bit of background.  My Clio 182 has been off the road since 2013 when the engine was trashed.  I bought it a couple of years ago, put a low mileage replacement engine in it and have been struggling on and off since to get it going.  When started it revs to 3000rpm on its own and as it warms starts to cycle between 2000 and 3000 revs.  Operating the throttle will increase the revs above 3000 but otherwise it is revving on its own with the throttle butterfly closed.  Have checked for codes but nothing showing up.  I have tried so many things I am about to give up!!  Timing is spot on (set using Renault tools), earths are good, air temp sensor, manifold pressure sensor, ecu/uch, crank position sensor, injectors, dephaser all changed.  Any ideas? Wiring? What else to try?  Any ideas/ help much appreciated.
