Poor mpg, low temp
DomP182
  ph1 172, Arctic182
I've noticed my mpg has got pretty poor, around the low 30s and my temperature gauge sits a bar sometimes two below the halfway that 1*2s always sit at.
Is this a fault thermostat, CTS or both/neither?
DomP182
  ph1 172, Arctic182
I used to get high 30s even 40 on my 20 mile work commute, no town driving. My ph1 was even better
DomP182
  ph1 172, Arctic182
Do you get heat in the car? I would say a sensor.
Yeah I'm getting heat, I'm going to use it for a sneaky few days away in Snowdonia so it will be interesting to see what mpg I get on that run. The thing that I noticed first was the needle below half way, all 1*2s I've had were bang in halfway
DomP182
  ph1 172, Arctic182
I remember changing one on my Valver years ago because it wouldnt run properly from cold
DomP182
  ph1 172, Arctic182
if you’re using a Bluetooth obd with the torque app you can read coolant temps.
I would side on it being a stuck open thermostat personally.
Might get a bluetooth obd reader then, any recommendations?
DomP182
  ph1 172, Arctic182
I've bought a bluetooth obd reader just now so woll have a look when it comes
DomP182
  ph1 172, Arctic182
@DomP182 but then if you do a long run over a weekend and get low MPG, surely you would save most the cost of the parts in using less fuel???
That's a good point but it's the 172 or our Tiguan up to Snowdon, I cant resist a blast up there in my car. The thermostat/Cts can wait
DomP182
  ph1 172, Arctic182
Got the bluetooth obd reader and downloaded Torque lite. Fair to say I dont understand a lot of the readings it gives or their relevance. Is there a guide anywhere as to what they should all be?
I can see it will be useful though, how accurate is the mpg average etc?
Mr Trailer Man
On the home screen, go on Realtime Information.
Mine loads up a page with dials on by default it has things like RPM, throttle and coolant temp.
Do yours look similar?
DomP182
  ph1 172, Arctic182
On my phone there is no home screen of preloaded dials, I had to put my own on. Also cant see realtime information, should I get torque pro instead
Mr Trailer Man
Could be different, mine is the pro
DomP182
  ph1 172, Arctic182
I dont understand half of the stuff that is recorded to be honest, hp but no bhp?
