Urgently need 3 monitor graphics card
GrahamS
  335d, GT4
Help me!
Need a 3 monitor graphics card, have no idea what I’m looking at. Not used for gaming, just work. Ideally not mental money.
PC has an AMD 8350 CPU AND ASUS m5a97 r2.0 mother board.
Monitors take HDMI
Thank you
Darren S
If you're not striving for current level level tech and want it purely for work, you could do a lot worse than a 1650. I've got a standard 1050 installed in my works PC. Does me fine supporting three monitors, though specifically going for 3x HDMI ports is a limiting factor these days.
Do you have any monitors that support DisplayPort? If you did, mixing and matching those with HDMI would give you many more options.
GrahamS
  335d, GT4
I’ve had to change the monitors I ordered as they were on back order. New ones have DP so that was a result!
GrahamS
  335d, GT4
Nearly set up now, waiting on a display port cable for the last monitor. Frustratingly the monitors only came with HDMIs. For now two will do. Quite a large set up. The monitors massively overflow my desk but who cares, this is now like the workstation I'm used with everything at the right height and properly setup.
GrahamS
  335d, GT4
That lack of screen alignment is disturbing.
That's part because of the monitor arm, although I can adjust it out, I think (middle and right on same arm). But at work I have my phone under there so I'm weirdly used to have that one a bit higher!
Typhoon
Gangsta
  TT
Agreed with @MarkCup ! I never thought my OCD was too bad until I almost wanted to gauge my eyes out after seeing the monitor height difference.
Getting there tho mate.
GrahamS
  335d, GT4
😂 yep, I bought it like that and it works a charm!
One week into this and it’s all working very nicely. No back ache from the monitors being at the wrong level.
