Gen90 and TPS
Car  Clio 172 Cup
Hey guys, Installed a new ITB setup from Pure, and I have a Gen90.
Wired up the TPS, but in GenTuner, the TPS is showing at 100%.. even with the wiring apart..
What's wrong..?
Also, how do you put a map on there.. I have an ITB base map to put on.
End thread, I've sorted it.
Found a break in the signal wiring..
Hi Benny, just been scrolling through as I have this fault when I rotate the tps to set up, the raw value is staying the same. Where did you find the break?
Many Thanks
Jack
