Coilover gaiters
Kev@KAM
ClioSport Trader
  Badass Toyota
They keep dirt out generally. I use them in combination with ACF-50 or Corrosion block. Double protection.
You want to give everything a good clean after winter though or if you've accidently crashed into a field...
Bankrupt_drunk
  Clio 172
Or if you've been driving up and down the A14 which, due to the roadworks, has been covered with mud for the last 3 years.
frayz
I use ACF50 and the Motamec items.
Clio_fool
Took mine off after a year or so the other month:
The covers were filthy, the shocks were lovely and clean😊. Mine are these ones on ebay: 154005908157
McGherkin
McPension
100% worth it.
As above, use some sort of grease/corrosion inhibitor to protect against trapped moisture and make sure that the bottom velcro of the sock doesn't sit on any important threads as, if anywhere was going to corrode, that's where it would be.
joe hk&uk
  182 cup
hi folks can anyone point me to the right direction that they do 3 diff length 13" 16" 19" so which one r suitable for 182 cup front&rear shocks?
thx in advance!
