clutch damage
For short tracks it makes sense.
If it was a Silvertone, Spa or Nurburgring you'd max out in 5th 😂
That would be ok for me, if the car is optimised for Brands Indy and Lydden Hill, that's where it will get at least 90% of it's use.
The occasional trip to Snetterton might be a bit painful, but I'd have to live with that.
I'd love to drive Spa but I'd be touring round, I'll never do enough laps to learn the cicuit.
Just a quick update, mainly to say thanks for all the advice, I have heeded it, and once again this forum has proved itself invaluable in providing free specialist advice on a car I don't have much experience with.
The gearbox is currently with Mark having a diff service, replacement casing, and most excitingly, a 13/59 final drive.
I have a Sachs clutch ready and waiting to fit, with new bolts.
While the engine's out I've had the intake manifold vapor blasted and am currently polishing the tracts.
I've ordered a 64mm throttle body, which doesn't sound much increase over 60mm, but if my school boy 'pie are squared' is correct is almost 14% increase in intake area.
I have DEI titanium super duper lava rock exhaust wrap for the manifold and decat pipe!
I've read that these mods will gain me at least 75bhp:)
My bank manager ( Mrs Banhama) has politely informed me that given the above spend I don't have the budget to further indulge in throttle bodies, cams, or indeed beer for the foreseeable future.
Meantime it looks like lockdown means I'm not going to get the car back on track this year anyway.
Can't wait to get it all back together and give it a try, but will have to wait to the next Lydden trackday or race to see how it's all come together.
I'll be back to update once we can get back on track.
Many thanks all, and all the best during the next few weeks
Andy
Gearbox back from Mark @NorthloopCup ,having had diff service, new final drive and new casing.
Excellent service as usual, highest recommendations!
No excuse now, I've got everything I need including the precious Redline MT90
Now to slowly and carefully put it all back together..........sure beats decorating!
Hi Andy, good to see your making progress for some reason the forum stopped sending me notifications so I've missed lots!
Have you found the reason for the repeated failure then, perhaps I'm missing something a few pages back but...
I just don't buy your driving style as being the reason for failure. I've seen and done some really horrid things to cars and have never seen clutch failure like that especially so soon after fitting the clutch.... I know people have said you were a bit harsh with changes etc but I bet you many here on track are more abusive.
Basically I think it would be an awful shame for you to put it all back together and experience another failure! Nothing much helpful in that statement I know, but the only original change you made was the flywheel before all of this kicked off.... any chance of getting a standard flywheel to measure up just to be 1000% sure its nothing to do with that?
Hi Rob, It does indeed appear that I am guilty of what one manual politely describes as 'incorrect driven practice'.
The change down for the elbow at Lydden is just at too high road speed, but holding third doesn't work as you're then directly up a steep hill.
Both failures have been immediately after that corner, and having checked my notes I must admit to getting the history a bit wrong:
I hankered after an LSD, but only had it fitted after the failure of the original clutch, at which time I also had the flywheel fitted.
I always put that clutch failure down to the age of the car, but it wasn't your normal friction material wear.
We trailered the car to Snetterton, got it off the trailer and it then refused to go into gear. Sounds familiar!
Notes in my big black book show that the prior to that I had trouble getting the car into reverse, but suspected the linkage had slipped.
I tinkered with the linkage but that was fine, then changed the gear oil, but it was actually a clutch issue
I think this was the first failure due to incorrect driven practice, but it wasn't quite so drastic due to no LSD
Because I got a garage to fit the new clutch I never saw the old clutch, and don't know what the failure actually was.
( Worth keeping notes, but helps if you actually read them when you have an issue. My apologies )
Before buying the Sachs clutch I spoke at some length to Nick at PMS about the flywheel and clutch.
Reportedly there is no historic or physical reason to blame the flywheel.
We also discussed using one of my two perfectly good friction plates in a Sachs cover, but after a measure up they are both thinner from new, and clamping force could be compromised.
It seems the Sachs clutch cover up to some pretty severe abuse, but I hate the idea of fitting a stronger part just so I can carry on beating the s**t out of it. I do try to be a mechanical sympathizer.
So given the fact I'm also running out of revs in 3rd at the end of the two mini straights it made sense to fit a different final drive.
I should then be able to use 3rd mid range at the corner where I had to change down to 2nd, and still have grunt up the hill, and also have time to use 4th on the straights.
That's the plan anyway, but it will now be a while until I have a chance to test it out. If it saves the clutch and shaves a few tenths it will be money well spent.
The rest of the stuff, polished ports, bigger throttle body, wrapped exhaust is all just Covid distraction I think!
Cheers, Andy
Quick update.
Sachs Clutch fitted
Gearbox re-fitted and ready to go back into the car
I'm happy to report that having fitted everything back into the car, drip-fed the gearbox the special MT-90, and re-filled the coolant and PAS fluids I finally plucked up the courage to start it.
Bloody hell.....it all fired up okay and after bleeding coolant and PAS I tentatively drove it forward and backward and it works!
Unfortunately I can't drive it on the road so need to book a trackday to give it a proper test. Seeing as it's now doubled in value, or at least money spent, I'm not risking breaking down on her majesty's highway and having it crushed by some jobsworth.......no tax, no insurance, no MOT, no car!
One thing that is immediately noticeable is that the clutch is so much harder to depress. Think I'm going to have to go to the gym! It won't be a problem on the track, but i don't think I'd want to use it in stop-start traffic.
It makes absolute sense that a clutch that can transmit more torque would have heavier springs, and therefore be harder to release.
I was surprised because this is a 350nm clutch and I had a 1000nm clutch in the Subaru which was lighter on the pedal, but that was a hydraulic system.
So really I'm asking can anyone else with a Sachs clutch confirm that it's a lot heavier on the pedal?
I just want to eliminate the cable, which I have replaced with a new one that is supposed to be OEM, and has all the fandangly damper bits on the end. But the one I took off, which I though was OEM has none of that.
Please see pics below. Can someone confirm which is the genuine article:
New Cable
Old cable
Many thanks
Andy
It makes absolute sense that a clutch that can transmit more torque would have heavier springs, and therefore be harder to release..
Thats not strictly true. It really depends on the company making it and whether they make the changes to alter the cover internals to suit the car. Most likely its a semi-generic cover thats used on multiple applications and drilled to the correct fitment so it does not go through specific car optimisation. I had to get my own clutches made to sort the issue to a pedal feel I was happy with.
Quick update.
Sachs Clutch fitted
New Cable
Old cable
Many thanks
Andy
Andy, I'm running the same Sachs ZF clutch kit with a lightened flywheel supplied by PMS and can confirm the first time i drove it, i stalled it because i was not use to the clutch pedal as it definitely felt heavier. But over the course of a few days of daily driving it, it became good and seem to bed in nice and not that heavy at all. Therefore i think with time it will get better, or at least you become accustomed to the clutch pedal weight.
Many thanks for that first hand experience of the same set up. Very useful indeed. I won't mess about with the cable or anything else until I've had a chance to give it a good drive.
I've stretched my mind back to 2003 when I had an rx-7. New uprated clutch fitted in Reading and the drive back to Kent, including the wonderful M25 almost disabled me. But yes either the clutch got lighter with a bit of wear, or I got used to it, and after a while didn't even notice.
Cheers, and thanks for the help
Andy
After 5 x fifteen minute track day sessions, a qualifying and two races, all at the clutch-killing Lydden Hill, I think it's safe to say the clutch issue is now solved.
Many thanks to you all for your help.
I'm now trying to get to grips with the new gear ratios, but they do work well. I just have to unlearn the old muscle memory, as the shifts are now in completely different track positions.
I do have a couple of totally unrelated issues now, one is engine breathing, which I will raise in a different thread. But as far as this one goes, the Forum has proved invaluable once again.
Andy
So in summary what was the issue(s)?
I think simply the change down from 3rd to 2nd at race pace was too harsh for both the LUK and Valeo clutch covers.
I applied 2 solutions at the same time, so not sure which has had the most effect, but I'm sure both have helped:
Sachs racing clutch, and
13/59 final drive, which has changed the gears used at Lydden to 3rd and 4th, rather than 2nd and 3rd.
The speed at which I can take the Elbow now sits more comfortably in the rev range of 3rd, rather than near the top of 2nd.
Also the straight gear change is a lot cleaner.
Here's a link to Race 1 video, the Elbow is the only left hander, it's still quite a hefty down shift, but now I don't have to change up on the way up the hill
( Ignore the very weird rolling start, and my bashing the limiter rather than changing up and possibly letting a BMW past, I'm ashamed of myself)
Quick update.
Sachs Clutch fitted
New Cable
Old cable
Many thanks
Andy
It's a few years late but I found this thread through searching trying to find my issue with not being able to get into gear when engine running, or when off and put into gear it would move when starting because of not disengaging.
I bought a new cable from RPD and I too was confused if I had the correct one but couldnt find anything here about it. I had bought the top photo but the one on the car was that of the bottom photo.
Using the guide on here to change the cable, I found it extremely good and am amazed, like yourself at just how much free and decent knowledge this forum has between all of its members, a true blessing to the Clio enthisiast.
However after changing my cable, it won't engage as said and I need to find out why?
I was doing a bit of research before I call the garage who fitted my new clutch, (again from RPD genuine with release bearing) less than 1700 miles / 11 months ago.
I have been driving it relatively hard but not anywhere near a track, accept a 6x 1/4 mile runs back in February after about 1000 miles of driving, I don't use it that often but mainly spirited drives when I do.
In the past few weeks it has been having a little rumble when idling but as soon as I put the clutch down it stopped, which I felt was weird. It then started having trouble getting into reverse, and then on a drive the other night I found the only way I could change gear was to rev match and brought it home with minimal gear changes. On returning home I had to shut off the engine to put in reverse then (even with foot buried into the carpet) it rolled back as I started the engine.
It goes between gears when engine is off but locked in neutral when running, which your story about gettingnit off the trailer at Snetterton flagged as a similar thing.
Without having the ability to get any pictures of the clutch like you have I'm trying to piece together if it could be a clutch fork pivot joint worn our or what else it could be?
Thank you for posting the pictures of inside your clutch housing, I can see what it is that I'm looking at and how it should be.
Just from the very small information I have put, would you think that my clutch is done so soon? Or may it be down to faulty instalation?
Any help is greatly appreciated like always.
I need to go back and check through that BMW thread to see what that's all about too as was just reading through this from page 2.
I hope you don't mind that I've added onto your thread after 6 years, but I feel I may have the similar issue and starting a new thread when one exists after I did some searching I thought made more sense.
Many thanks, and my 2003 Flame Red 172 would be very grateful also!
Is the pedal actually engaging the clutch properly?
Get it in the air (not on a scissor jack, widow boy) and start it up in first and depress the clutch to see if it disengages. If it doesn't, do the same but within the engine bay.
These are the 2 clutch cable ends
I tried it when the wheels were off and I could go through the gears 1-3 with the discs rotating (had to turn ESP off as that was throwing up due to no resistance) and it showing 40mph on the dash. Didn't really want to go into reverse though, I thought it needed to have some sort of resistance too it. Got it back on the ground today and that's when I found it didn't engage.
I hate getting get it up at the best of times (no inuemdo meant) so will have to build my courage up again...and maybe get a proper 3T jack
There are the 2 clutch cable ends
Quick update.
Sachs Clutch fitted
New Cable
Old cable
Many thanks
Andy
