Does the Horn work without the engine on?
Bit of an odd request here. Going to try and wire up a horn button on the dash this evening. But the engine isnt in a state where i could switch it on. Just wondering if anyone knows if just the ignition would power the horn? or if the engine has to be on....
Before i go chasing wires thinking its not working etc.
TheEvilGiraffe
South East - Essex
It will be off the perm live, otherwise you couldn't alert someone to your position / danger if you were parked.
Ph1 stalk is usually the easy go-to assuming you've an aftermarket steering wheel ?
Good point. Ive built a small switch panel so I’m going to run the wires to there I think. Presuming there’s just two wires connecting to the steering wheel hub somewhere. Was going to just extend them to the centre dash.
TheEvilGiraffe
South East - Essex
Do you need it to be road legal ?
Just perhaps be careful you can reach it when strapped in ?!
LeeRS
Just jumping on this thread save starting a new one.
Just put a sabelt cup racer steering wheel in so obv no horn button.
Plan is to put a momentary switch on the dash somewhere.
I touched the two horn wires together yesterday and it honked as it should.
Today I fitted the switch which lights up when I press it but no honkey honkey noise.
Any ideas?
imprezaworks
  Mk5 Golf GTI :)
This help
