RS tuner Locked to one car?
RichValver
  Clio 16v/172 daily
i always assumed the RS tuner was locked to one car for the maps, is this also the case for the modules?
I have tried switching airbag lights off on 2 other cars now and it allows me to switch off each airbag sensor but the light stays on and the codes are still there
Is this just a way to get more money from the rs tuner so it can only be used on one car to code out airbags?
Or am i doing something wrong here?
Rich
RichValver
  Clio 16v/172 daily
I have turned off airbags and done ABS routines on mine on different cars. As far as I was aware its only the the writing to the ecu thats locked.
This is what I thought it was. But it's allowing me to switch each individual sensor off yet the codes still appear when I clear and refresh the codes
Retested in on my own car and the light/codes go out no problem
I'm not sure what the issue is
JamesBryan
  Titanium 182
Airbag module doesn't need a licence, can do as many as you like.
I've done a couple with mine.
Screenshot the airbag configuration screen if you can. Might be able to help.
RichValver
  Clio 16v/172 daily
This is what I thought, I must be doing something wrong.
JamesBryan
  Titanium 182
Are the sensors that you have turned off unplugged?
If you disable something it needs to be unplugged otherwise it will still see something as being there.
If it is unplugged then it could just need a cycle of the ignition. I've had that happen before.
