Cam finger followers: any difference between phase 1 & 2 172?
Fishfire
  Clio 172
I need to replace all my followers and having looked on Trodo's website, they have INA finger followers but for the engine code CBOM which I believe is the phase one engine.
They're quoting (amongst many others) as fitting these F4R engines. One is the 182 and the other a phase 1 172
Now these are significantly cheaper than I've found elsewhere, but I wanted to confirm with those in the know, that these will indeed fit my phase two.....or not as the case may be!
The INA part number is: Finger Follower, engine timing INA 422 0009 10
Cheers!
Fishfire
  Clio 172
They’re all the same mate in the 1*2 and 197/200.
Make sure you definitely use INA ones as well.
Ah many thanks.
I've used Trodo before as they were recommended on here for genuine injectors. They're definitely quoting as genuine INA.
I'll get them ordered
Cheers!!
Fishfire
  Clio 172
16 INA roller finger followers arrived today from Trodos in Latvia.
Genuine INA. In the uk I was looking £200+
These were £76 delivered!
Second time I've used them now and defo recommended 👌
