From here it started a BAD year for the Clio
A friend rented a Mini Cooper S 2.0 Turbo, so we decided compare the Clio with the Mini, but in the middle of the night the downpipe decide split in two parts hahahahahaha
So i stopped at a gas station and started remove the whole Exhausty
Ready to test xD
And the result:
Clio 3 x 0 Cooper S
Clio 0 x 1 Gearbox
404 Error Circlip Not Found
Circlip replaced and time to remove the downpipe to fix it, while i was disassembling the downpipe to fix it, i find another problem
I use a external wastegate from Tial for better boost control, so the original wastegate has to be welded to stay closed all the time and only the external wastegate control the pressure, so that how i found it
Another thing fixed and a new test, decided to test the ceramic coat on the exhausty manifold and downpipe to reduce the engine bay temps
And damn the results was really impressive, the turbo spool started 500rpm early, more agressive and more boost on high rpm, now i started run with 17.4 psi and omfg the car changed a lot.
And we know when the car start to be to so agressive, fast and pulling reaaally hard this mean that the car will break soon HAHAHAHA
So 2 weeks later that happened:
A guy was about to overtake me and didn't see that there was a broken car in the side lane, instead of braking he decided to try to pass between the two cars
the result:
The engine started to spiting more oil from the breath oil, two weeks later the engine said goodbye
What i found:
So at that moment i started do realize how much time and money are necessary to keep the car running fine using as a daily car, realize how much money still needed to make the project get a little close to project we can found here at CSOC, so i decided stop it, keep it simple and original to be able to use all day without so many problems and less fun
The last thing i will try is the F4R engine with MS3 ECU and A/C.
Decided to sell the Clio Sport bumper, wings and headlight after almost hit the car 3 times, these parts have a very high value here, so I choose to sell and with the money buy a car for a simpler and differente project using the mechanics parts that I already have.
Interior almost original with megane steering wheel
Engine and gearbox out, engine bay almost ready to be cleaned
