Timing question.
Jack1998
Car  Renault Clio 1.6 Rsi
Afternoon all,
Just a quick timing question I hope someone can give me a bit of guidance on.
When putting the horseshoe tool in to lock the cams I have to put it in the exhaust cam with one side of the horseshoe twist it around to then get the other side in the inlet cam. After that the horseshoe is pretty well wedged in there, I know with the none gen tool it's advisable to put a feeler gauge in there to space it out and when it's all timed up the horseshoe should slide about freely. I have the genuine Renault tool and there is no space for a feeler gauge and it just wedges in there tight. Is this normal? Don't want to time it up wrong and ruin it after refreshing the bloody thing!
Cheers,
Jack.
Yes, there won’t be space for a feeler gauge but once timed up it should slide in and out relatively easily.
I must be doing something wrong then as my exhaust cam seems to 'bounce back' a few degrees after finishing up and I can get the tool back in but only with a bit of fettling
Have you got both pulleys loosened off? Make sure you can move them on the ends of the cams then once the tool is in tighten them both up with out them spinning. It’s tricky and may take 2 or 3 attempts but you should get there.
Yeah, they were slack, rebuilt the top end so everything started out in bits, as long as that timing tool doesn't need to slide about I'll just give it a few more goes until it's perfect, cheers mate.
Also worth removing all spark plugs so you are not fighting against it,
Try 20 or 30 attempts !!!!
