Driveshaft play
  Clio 182 arctic
Hi guys
How much rotational play should be in the driveshaft. I can rotate mine a fair few degrees before it starts to 'engage' for want of a better word.
I'm getting a knock when setting off and letting off the gas at low speeds and that's the only thing down there I seem to get any movement out of.
Any ideas?
  Clio 182 arctic
Strangely the whole shaft rotates not just the end. So the play seems to be the gearbox end I would suggest. Assume this is normal. Other than the knock when setting off and letting odd it seems to drive okay
Clio_fool
Like this?
A week later the gearbox s**t itself, planet gears chewed themselves to pieces.
  Clio 182 arctic
Like this?
Crickey. Not that bad.
Just maybe say 10-15 degrees or so but noticeable. It has been like that for years from what I recall just wondered if it was normal as it is still on the original shafts. 150k aswell.
Just trying to rule it out from causing the knocking I can now hear. MOT next weekend so hopefully he will find what it is
CasualBG_182
Did you ever figure this out?
