Rota TFS3
Car  BMW 120D M Sport
Hello,
Has anyone had any experience of fitting Rota tfs3’s to a clio?
You can get them in 15x7 and quite a few different offsets but unsure if regardless of this some wheels just wont clear the calliper or not?
Found this thread through Google as I’m about to collect some tomorrow I’m basically the same spec as Cup Turini’s but in ET35
I currently run PMS 18mm hub centric spacers up front and PMD 10mm rear axel spacers so in theory these should be same but with a tiny bit more poke.
mid that’s the case then I’ll have to fit my camber bolts and get same camber shims for the rear
Did you get around to fitting some?
I didn’t... i went with the play it safe what everyone else has (2118’s 😂)
however i will probably be after a set when i see yours fitted, Upload a photo when you do
They're basically a copy of the Enkei rpf1 wheel. Ultralite do a set too, if you search these, you'll find a few examples.
Post #3614
Did you get around to fitting some in
I’ve had all the usual wheels you’d find so I wanted something different.
they arrived today and I’m very pleased. Will keep you updated once they’re back from my detailer for a ceramic coat and tyre fitting
Got them on finally. I went with 16X7 ET 38.5, the needed spigot rings but that was it. I ceramic coated them inside and out and fitted some 205/45/16 Toyo Proxes T1R. 18mm PMS front hubcentric spacers and rear 10mm PMS axel spacers. I like the fattier look of the tyres at this sizes over the stiffer looking side walls of AD08R’s for example.
No rubbing at this height either so may drop the front a tad but very happy with them and they’re super light too!
