Hard brake pedal
  Renault Clio 172
I’m planning on replacing discs and pads all round and the rear brake pipes,I’ve managed to get the o/s/r but no look with the n/s.however I’ve noticed when I press the pedal all feels ok and the brakes work fine,but if I go to press the pedal again it feels very hard and there’s little effort which can be concerning as I found out at Croft lol,any ideas ? Cheers
JamesBryan
  Titanium 182
Have a look at the hard plastic vacuum line from the inlet manifold to the brake booster.
They can melt and collapse, giving you the symptoms you've described.
JamesBryan
  Titanium 182
To answer your other point, one of the rear brake line pipes is no longer available from Renault.
I went for an aftermarket braided line instead, from Pro Line braided lines.
  Renault Clio 172
I’ve checked the pipe,it’s been wrapped in foil and insulation tape as it’s looks to have melted,also not available from Renault.
George@RTR_Parts
ClioSport Trader
  need BRAKES? PM me
BTT should be able to help with the vacuum line.
If wanting to change/upgrade the brakes for track, send me a PM as I can supply various discs, pads, fluid, braided lines (kits and custom both Goodridge and Hel) , OE Renault brake lines etc etc (y)
  Renault Clio 172
Try and get one from a Renault Sport breaker like BTT Motorsport.
It’s had been well and truly bodged I’m surprised it even worked,I’ve made my own out of some 10mm brass pipe,thanks for your help 👍🏻
thanks I’ll be in touch then as the wanting to replace the brakes for fast road and track days 👍🏻
