Oil Loss On Turbo Engine
t90_lle
East of England
So I appear to have blown all my engine oil through the breather over the block and gearbox. I was just wanting to know potential causes for this to do it as an idea to give my mechanic. I’ve topped the oil back up to see if the is an actual physical leak anywhere as I’ve had no drips on the drive before seeing the rainbows yesterday from the rain. Any guesses or ideas would be appreciated.
I Changed My Name
Depends if you're doing wet or dry and with the car up to temp or flat cold
Flat cold dry you should get like 180-190psi for a good cylinder. Anything below 175 and it's a bit shite
t90_lle
East of England
I’m driving it down to see Alex in the new year on the 7th Jan, So what about hot/warm temp pressures or it’d best to let it cool down 1st I reckon?
I Changed My Name
Alex will probably letit cool of a bit first. Tbh you can comp test them hot but your readings will just be a certain percentage higher as the rings close up
t90_lle
East of England
Wouldn't harm it being a bit warm, as realistically your engine doesn't operate at stone cold for long.
Brilliant cheers for the info gents!
Just hope it goes well and I don’t need a rebuild 😂
Donny_Dog
  Jim's rejects
I had similar, thought the rings were toast.
I'd put too much oil in. Not knowing exactly what I should put in, after fitting an oil cooler.
and having a few beers doing a service.
