Headlight restoring?
Poopensharten
  Golf R
Afternoon folks,
I’m trying to find a thread someone in the last few months posted about a product they used to restore headlamps, can anyone kindly point me in the direction please?
cheers!
Fantastic Nostrils
  Cumpact
As above. The autoglym kit is great. Shove the attachments onto a drill and you get gradually finer grades of sand paper. Takes most of the hard work out of it.
Pro Tip. Buy some clear coat to go over the top after you've finished as otherwise they'll fade again in a few months time!
Rich-D
  E90 LCI 330d
I've done a set on a BMW E39, it was a massive improvement, followed some youtube guides and it turned out very well
Darren S
I've used a number of kits over the years with varying degrees of success. By far the best option for me has been a more regular treatment using this.
Rich-D
  E90 LCI 330d
What kit did you use Rich?
I didn't use a kit as such, I followed a couple of guides online, which just used progressively finer grades of wet & dry, followed by polishing with a DA to get that final finish. Will see if I can find what I followed.
When you start at first and the lenses are all hazed up from sanding, you think "fcuk I've ruined this" but as you keep going things improve and suddenly they're crystal clear, just a bit dauting at first.
The difference was massive though, they were a right mess before, looked almost new after, will upload some pics.
Rich-D
  E90 LCI 330d
Here you go…
Before & after for comparison:
Mid grade stage, when I thought they were never going to be recoverable:
But ended up looking like this:
Just take your time, it's not difficult and that was my first attempt.
Colin-S
  172 Cup
I used the 3M™ Headlight Lens Restoration Kit. Think it was around £20 a few years ago.
I did regret not closing the bonet before polishing as it went everywhere...lolol
Darren S
Went out this afternoon and did the headlights on both cars. No idea where my 3M tape ended up, so just used standard masking tape - better than nothing I guess. Just used the combination of Chemical Guys headlight restorer that I mentioned previously and the Porter Cable set to mid-speed.
The 182 ones came up well, but those on the ASX were much more impressive.
GrahamS
from a while ago now
You need to seal them with some kind of ceramic coating or lacquer otherwise restoration will actually worsen the issue long term and after 12 months you'll be back in the same position. I know because I didn't seal mine....
