CS Gold What have I done wrong?
Mr Squashie
CSF Harvester
  Clio 182
Just changed my rear shocks and springs and my car looks like a tractor. What have I done wrong?
I lined the springs up with the grooves in the spring mounts from the old springs, I checked the spring mounts were seated properly, but this doesn't look right 🤔
Mr Squashie
CSF Harvester
  Clio 182
Question about the front shocks now...
I don't have a 21mm offset spanner, can I just blast the top mount off with an impact wrench? Or do I need to go back to Halfords for the 3rd time today?
Speedo Gonzales
Aye razz the c**t off
In your case, hit it with your handbag a few times first to make sure it knows who wears the trousers in this house!
Mr Squashie
CSF Harvester
  Clio 182
Renew that bumpstop/dust cover before fitting. Give the shocker a tug
I get that the shock is compressed at the moment, but do I really have to reuse that grotty dust cover?! I kind of assumed that they'd be included 😐
Brigsy
  T.Turbo
Yep you need the dustcover as its got the bumpstop in it, which is secondary damping on stock shocks/lowered springs, its not included with the shock. Febi do aftermarket replacements which are ok and cheap, i wouldnt refit that one its knackered.
Mr Squashie
CSF Harvester
  Clio 182
Right, in which case I'll get some ordered. May as well go genuine though as everything else has been so far.
