How did your A/C cope in your Clio today?
Chocice
Car  172 Cup
My Clio 200 has just been regassed recently and when it was 40c today I could feel it if I put my hand over the vent but it was completely overwhelmed by the heat.
Didn't go out today, but did yesterday in my 182, A/C regassed over a year ago now and still lovely and cold. Not as good when sat still at traffic lights, but excellent on the move.
Errr...
Me on the way home
Got the Aircon regassed in the ph1 a couple of weeks ago only for the throttle cable to snap just before this weather. So had the cup with no ac today. Wasn't as bad as I thought it would be once on the move.
Maybe as the different Clio mks have come along the air con is progressively less effective due to emissions
38 in my 182, AC is mint. Works really well, really cold air pretty much straight away!
if you’ve had it regassed and it’s still not great I’d guess there’s a leak, often the valves are a weak point and are not checked on a pressure test / regas. My van has this issue, the valves leak and it wasn’t picked up on the pressure test.
It’s been done properly using an ac specialist I think it’s a combination of the bigger car and worse ac unit I would be interested in knowing if other mk3 owners had ice cold ac
Aircon is working as intended in my mk2 dci, feels pleasant inside with the windows up.
The Clio is of the road but even if it wasn't the AC was ripped out years ago, the Golf's condenser leaks and let all the gas out, so windows down it is.
The berlingo has no AC. It was a killer today travelling to digbeth and back to collect a wheel from powdercoaters
Oh I just had a thought I wonder when my cabin filter was last changed
Do that immediately! They should be changed every year really. You’ll be amazed at how much s**t they hold and therefore block flow.
