Can you make the head lights not come on when the car is started?
Car  clio 182
When I start the car the lights come on, you then turn them to side lights to get the lights to go off and side lights on.
Is there a way of making the lights only on when I want them on?
Turn the auto lights off if 172 twist the inner on the stalk that says AUTO
Cycle the lights on and off fast on the stalk.
Presume your sensor is blocked or not working properly.
Ok, it’s a 182 I should of said.
So ignition position 2 - switch the lights on and off fast and I should here a beep? Then they only come on when I want them on?
Or they’ve been programmed with Clip to be permanently on.
Really good, i do the geos myself as I have on the Lotus platform, and it was easy to setup.
I’m running 2.6 camber on the front but think it needs 3.
It needs a diff really but I’m not spending that cash!
What are you running?
