While sorting out the ex Mark Fish Motorsport 182 I came across a pipe with 90 degree connector tucked away inside the structural offside member just below the headlight assembly passing through a grommet. Upon tracking it back it follows the fuel pipe back under the car and then disappears up in front of the fuel tank alongside the fuel feed. I assumed it was a fuel rail return pipe but cant see what it was connected to. The car has the standard fuel rail. The car starts/runs with it as found. Any ideas and why it would be disconnected/hidden away [assumed redundant] ?
PS: The taut red wire is for the horn - its got an aftermarket crimp spade connector so will chase it back as the steering wheel is changed and no airbag/horn yet the car is MOT'd
