Non 172/182 shells - are they the same?
Greg.w
Car  Focus RS
Hi all,
Quick one. Are non 172/182 shells the same as a 172/182? Eg if I had to re-shell a 172/182, could I pick up a dirt cheap 1.2 etc and all the 172/182 bits would swap over?
Eg rear beams, front subframes, engine mounts, etc etc
Thanks
Hi all,
Thanks
I don't know why you'd want to make your life harder? It's easy to pick up a cheap 172 nowadays.
Just thinking if you've got a rusty complete 172/182, or its been rear ended or something along those lines. You can pick up a 1.2 etc for a couple hundred quid.
I think I saw that the non 172/182s are less prone to rust due to no side skirts?
Hi all,
Thanks
Everything in theory would swap over. Although tough to find one without a sunroof so possibly be better with a campus model or similar. You’d be correct that they are a tad less likely to rust due to not having side skirt brackets riveted on.
A 172/182 with a sunroof would be kinda cool? 🤣
Hard to find a non leaking sunroof, I swapped a rear ended 172 into my non sport with sunroof back in 2009/10
Fantastic.
So what's actually different?
I'm assuming front subframes and hubs etc are different. But what about rear beam? Front wings?
You can use the front subframe but it’s missing a hole for the gearbox mount so if you’ve got the 1*2 one there you’d be as well changing it all with the wishbones etc.
Rear beam is different.
Sport wings/full body kit is different.
To be honest you really do just need to swap everything in from the sport.
I wouldn’t even bother as the looms on the sport these days have seen their best days. That’s probably where most issues are with them wiring being a total ballache. You start to disturb it and it’s going to be issue after issue. Be better spending the money buying a good 172 or 182 to start with and just leave it as is.
Resale value in the future is worth considering. Non sport converted will be worth less than a genuine sport. All depends what you want it for i guess.
Are the rear quarters the same? Or sport models flared a little?
Yeah good point tbh. If its a dedicated track car then it would matter I suppose
Identical shells if you get one without a sunroof, myself and @aldo_87 have done a couple of reshells with ours, much better condition shells on the non RS cars now. As brigsy says, only worth it if it's a long term project so future resale isn't a concern
Insuring it will be interesting too I'd imagine, wouldn't it essentially be a modified 1.2?
No idea what the legality of it would be, but if you had a bare shell, what's stopping you from putting the 1*2 VIN on the 1.2 shell and using that v5, plate etc.?
I had a flamer that was hanging with rust so it ended up stripped bare. Found a 57 reg black Campus that had been garaged for the last 10 years which was £800. The shell is in really nice condition.
I used the complete wiring from the 172 and laid it into the Campus. I think that was the most different area of the reshell.
Hopefully I'll have mine running in the next month or so.
I expect that if you had a matching colour for your donor, black, flame red etc it would be unlikely to come back at you.
It's pretty illegal though lol
I worked with a guy who built a rover V8 hilux on a defender chassis. It was his daily for years running on lpg and all was fine until one day he was pulled and asked why anpr said his Toyota was a land rover? He had to have it inspected like a kit car and it ended up on a Q plate after.
Makes sense, not something I've got the skills to do (re-shell a car) anyway, just an interesting thought.
Two essentially identical bare shells next to you, one is a rusty 182 other is a 1.2, swap the VIN plates over, bring all the 182 gubbins over, give it a respray and I'm not sure anyone would ever be able to tell.
Obviously never do that if it's illegal or whatever :ROFLMAO:
