Fishfire
								Clio 172
				Hi All,
Hope someone can shed some light on my current heater fan woes!
So my fan was stuck on hot, but everything else worked fine, so I knew it was split plastic in by the motor. Easy enough fix if a bit awkward.
So I removed the motors, fixed the split ring and reassembled through had a mare trying to get the heat control motor to line up again but seemed to get it in OK eventually.
So, after the fix, I turned on the fan......and nothing g but cold air 🤷♂️
Thought I.may have blown a fuse, so I checked every single fuse, which were all good and tried again, but now I've got no fan either!
I've bypassed the resistor pack (which is only a month old) and the fan came on full though still cold but the blower positions refuse to change and the climate control doesn't seem to be working, as in if I put it in AUTO at max temperature it gives it zero fan.
If I bypass the resistor pack, I get full fan regardless of whether it's on auto or off.
What is the holy smurfballs have I done!?
