Hi guys,
I just want to apologize in advanced, in case this comes across as a little loopy. Before you conclude that I am a f@#$ing idiot, please stick with me and have a look yourself.
I've had issues with my EDC and have been digging around every corner of every forum, Reddit, and Facebook for information about the problem.
I've noticed a trend that seems to be pretty consistent. You can see for yourself by searching this forum, Reddit, or Facebook Renault pages for "check auto gearbox" and then click on a user profile to see what else they have sought help on. I know that it sounds absolutely insane, but it won't take you more than a minute to confirm it for yourself.
Those who post about gearbox issues also have threads or posts in their history related to one or more of the following:
- Coolant leak
- Thermostat problems
- Battery draining
- O2 errors
- Injection errors
- Parking break errors
- ABS/ESP
What do these all have in common? They are protected circuits in the engine bay fuse box.
Many people replace the battery, TCU, or other transmission components with mixed success, and often report that the unit eventually fails again.
Is it possible that gearbox issues have been misdiagnosed as TCU failure?
The fact that the battery sometimes remediates the issue may suggest that it is related to the electrical system - which may have potentially been damaged by coolant leakage near the transmission or wiring, causing voltage issues.
Additionally, the process of replacing the TCU requires the gearbox to be removed. In the process, this would require the mechanic to remove and potentially clean other connectors - which may suggest that the fix lies not in the new TCU, but the fact that things are disconnected and refreshed.
As such, my question to you:
If you have had gearbox issues or a TCU replaced, have you ever experienced any of these other symptoms - and in particular, coolant leakage?
It's also curious that the Ford cars using the same transmission also have coolant issues. Both components have been recalled.
- Coolant leak
- Battery draining
- O2 errors
- Injection errors
- ABS/ESP
