Lemforder for ball joints. Can‘t comment on track rod ends as always bought Renault. Might still be available.Done the driveshaft today and noticed the TREs and lower ball joints weren’t in the best of shape so may aswell change while I’m there.
Any links to what are the best recommended ones?
Yep, having taken them off of mine from previous owner fitting them I noticed there was a different brand on each side.Make sure you measure your current TRE as lots of different sizes out there.
I have the Lemforder TRE's on mine.
606745275 and 606745285 are the ones.
Lemforder | Euro Car Parts
Lemforder at the lowest UK prices from Euro Car Parts UK’s No.1 for Car Accessories, Car Styling & Car Care. Buy today Online, In store or by Phone + Branches Nationwide – Next Day UK Free Delivery.www.eurocarparts.com
These have gone up in price since I last done them on my old 172.
Sure they used to be about 15 quid each lol
It will get tracked up anyway once I have changed all the bits.
Anybody got a good track setup for me to base it on when I go for alignment?
I have camber boots fitted so can adjust
Any printouts so I can give to the guy doing it?At least 1mm toe out and -2.5 to -3 camber on the front.
literally talking a different language to me there 😂
This is for track car btw just in case that makes a difference
Cheers for the info James.No print out, mine is done by hand with camber gauges and string line.
The guy doing it will know what it means.
Those settings are a good start for track.
You will have to shim the rear stub axles if you find it's massively out.
Just checking these are the correct ones as it does say doesn’t fit my vehicle from the reg - noted you said it would say that.617745225 from euro for ball joints, they usually list the smaller non sport ones if you put your reg in, so use that part number.
Presuming these aren’t handed so just order 2?
Can you post pics? Walk away from it. It’s easy to get frustrated and end up damaging something else.Tried fitting ball joints and TRE today - the lemforder ones and I’ve had a mare.
Because I have the TRE and ball joint both out at the same time, the hub is able to move everywhere - still connected to the strut.
I can’t seem to work out how to line up the lower arm and the pinch bolt so I can get the ball joint in place correctly.
Do I need to pry the lower arm down? Push the strut up?
I’m about to smash it to pieces.
No photos as it’s dark in the unit now.Can you post pics? Walk away from it. It’s easy to get frustrated and end up damaging something else.
If it was me, I’d remove the damper from the hub, attach the ball joints to the wishbones and then to the hub, fit the new TREs, attach those to the hub, then refit the dampers. You’re not fighting with it then.
yeah I figured there was a reason you were fighting with it. Been there 😂Main reason for not taking out the damper was because I didn’t want to mess with the camber bolts but I think I’m going to have to.
Make sure the opposite front wheel is also jacked up, as it's likely you're fighting against the anti roll bar.
What's the difference between the two if they are not side specific?I have the Lemforder TRE's on mine.
Do you have the part number of the tie rods themselves? they're not specific to 172 and cup versions are they?
I can't find any lemforder balljoint on my local online part store with this code. Maybe because I'm based in the EU and not in the UK? The ones that appear to be the right part have the 2889203 code attached (they have the M12 size bolts as they should)617745225 from euro for ball joints, they usually list the smaller non sport ones if you put your reg in, so use that part number.
Try Lemforder 2889203, believe that's the same as above, but double check.I can't find any lemforder balljoint on my local online part store with this code. Maybe because I'm based in the EU and not in the UK? The ones that appear to be the right part have the 2889203 code attached (they have the M12 size bolts as they should)
