‘Bonnie Blue’ The RB 182
SharpyClio
See, mine doesn’t smell in the cabin on start up. Only when driving. And if I open the windows it’s loads worse. I guess as it’s vacuuming it in. It’s at its worse at motorway speeds….
Mines a bit like this as well, only when driving it hard though. Maybe it’s a feature 🤷‍♂️
Advikaz
Maybe? It doesn’t smell like fuel like race cars do though.
It smells of fumes. Gives me a bit of a head ache at times. I’d wondered if it was the decat, but it’s weird it’s bad at motorway speeds etc and with the windows down at speed it’s pretty strong.
SharpyClio
Yeah same, definitely not fuel. It is odd. I’ve never really looked into it.
Advikaz
Maybe it is normal dude. Doesn’t strike me as being ideal though.
I’m sure I’ve been in decatted 182’s that don’t though.. wonder if there’s a leak further up perhaps.
Advikaz
It’d have to be from the manifold, might have a look, see I can come across anything.
Yeah I’ll do the same
Unless it is as mentioned by underhill, the seals around doors and more specially the boot are shite and the vacuum from the rear is bringing the fumes in.
Who knows. You’d think you’d hear a leak or smell it around the engine bay wouldn’t you
Advikaz
Get it all vbanded and you'll have zero smells.
It’s got vbands mate. All bar the link pipe to the manifold which is spring flanged. I stripped that, cleaned it, sealed it and tightened it today
Maybe it is this though. Who knows. It is right by the gear selector. So could be coming up from there I guess
Advikaz
Just had a Google. Is that flange supposed to have a gasket? If yes, mine doesn’t……..
Mr Underhill
Mine and the gasket which I bought off K-Tec. It’s the only one that’ll get a decent seal on PMS exhausts.
Advikaz
That's the main one I meant you want vbanding 😂 They leak on a good day.
💩 let’s see how this goes. If it’s still s**t I may just bin the manifold and get one of those sexy b******s from pure
In for a penny in for a pound n’all that 🫠
Advikaz
Not sure if yours in the same but mine smells “hot” if you see what I mean, I thought my car was going to blow up at first as I wondered if it was overheating but it was fine.
I wouldn’t say mine smells hot. It just smells like a decatted car when you stand behind it upon starting up.
Except inside the car 🤣🤦🏽‍♂️🫠
Advikaz
Right, not sure if I’m being a pleb.
What can you guys tell me about this. I’ve gone in to the airbag module and turned all the sensors off. Attempted to clear the dtc codes and the air bag light is still on 🤷🏽‍♂️ it went out momentarily and then came back. And I don’t seem to be able to clear the fault codes that exist either
Think my other issues may be with the steering angle sensor …..
Also does it look like this ecu has been played with before ?
Mr Trailer Man
Show me the screen of the airbag config menu where you untick/tick the ones to activate.
Also, make sure you dont have any resistors in any of the plugs as it will think something is still there.
Advikaz
That'll be it then. I have resistors on the steering wheel!
Advikaz
Do a screenshot of the menu if you want and i'll check it.
You might need to cycle the ingnition before you clear the codes, they need to be orange before you can clear them. Red codes aren't erasable.
Hmmm mine have been red from the word go…
Advikaz
Cheers James
Will check all this in a bit.
Thanks for your help!
I’m now down to two error codes. Weirdly the EML has gone out now as well. But it’ll defo come back.
Looks like I need to replace or reprogram the steering angle sensor. And then I should be away !
Advikaz
Looks like a pretty good diagnostic tool that.
I’m happy with it tbh. It’s done what I need it to. It’s simple once you’ve got your head round it.
Have spent a few quid mind. Now have all the modules and all the maps 🤣🤦🏽‍♂️
Mr Trailer Man
View attachment 1679533View attachment 1679534View attachment 1679535
No worries mate.
Rear O2 will be because of the decat if you have one. Some bring up a light and others don't, mine has always been on.
I don't think you can do anything with the steering angle sensor with RSTuner.
