JToroPaz
								Renault Clio 182
				Anyone know a place to jack the rear of a 182 that isn’t the original jacking point on the sills, or the rear axle beam?
I’m replacing the rear shocks, the rear jacking points were mangled when I got the car I don’t trust them so I need an alternative. I normally use the rear axle. Only problem is I need to compress the rear suspension slightly while taking the shocks off. So I need to jack up first from somewhere that isn’t the sill, then compress the suspension from the rear axle. I just can’t figure out where that ‘somewhere that isn’t the sill’ is
I had a look through other posts about jacking points but couldn’t find an answer, sorry if this has been asked before
Thank you in advance for any insight!
