Can you have too many spacers
Car  Renault Clio 182
Hi guys I’ve fitted pms stub axle spacers wasn’t happy with one so put 2 on each side looks the stuff but when mates in the back and you corner hard or find a pot hole the wheel rubs quite bad on the arch wondering will camber shims solve the problem or should I just run with one each side ??
Many thanks Harry
Run one axle spacer, then a slip on to push it a little further if you need it
Camber shims won't get you anywhere near the angle you would need
