172 Cup poor handbrake performance
ex-Chinese Dave
The car has recently passed its MOT so the brakes are working fine but the handbrake is really poor. It’s been adjusted a couple of times but I need to pull up the handle as far as it can go to stop it rolling on a hill. Can anything be done apart from a refurb of the calipers? Maybe new cables?
16v_paddy
  Valvers & 172 Cup
There's quite a lot of adjustment available on the adjuster rod so I'd look at adjusting that a bit more
Also worth looking at the handbrake levers on the calipers, I had it on mine that although the levers were moving as they should, the piston in the caliper wasn't moving enough so fitted a new set of calipers & had to loosen the cables a lot after that
npt
  BMW 320d- 172 cup
Check the pads are fitted correctly, as in the tab is piston side, adjustment is a pain in the hole due to terrible location of adjuster above exhaust
MRBILLYUK
  FF Jeden Osiem Dwa
It could be your handbrake cables are old and have stretched which has been mentioned.
I was experiencing the same. It just wasn't holding very well on steep hills. I always leave it in gear anyway but obviously wanted the handbrake to hold the car.
My cables are only a couple of years old so ruled them out.
I rebuilt the rear calipers and they're now holding the car as they should.
For new handbrake cables you can pick them up from here.
ex-Chinese Dave
Working through issues on my car and we are back to the rear brakes. I've just bought some new Eicher rear pads to try but looking at the discs do you think they should be changed as well? I feel they should be if new pads are fitted. If so, which of these discs would you recommend? The car is for road use only and totally standard.
16v_paddy
  Valvers & 172 Cup
Those discs look mint to me, I wouldn't bother changing those, especially if they're genuine Renault ones.
Also with how disgustingly expensive the genuine ones are now it's a bit of a minefield with the aftermarket pattern parts as a lot of them use dogshit bearings - I vaguely remember from a while ago that Mintex & Brembo were particularly bad for it because a lot of them were Chinese knock-offs - I'd trust SKF/SNR items as they are the OEM for the bearings and I've seen a few people say they are spot on but other than those I don't really know which ones are good or bad 🤷
16v_paddy
  Valvers & 172 Cup
Although saying that, because it's a Cup without ABS you can use rear discs from any other MK1 or MK2 Clio as the discs & bearings are the exact same parts and the part numbers are only different because of what abs rings are fitted to them.
I managed to find a set of genuine discs for a 2006 Campus on eBay for £37 delivered, I originally got them for my Williams but they're on my Cup now instead.
If it's a set of genuine discs for a MK1 or MK2 Clio from 1990 up to 2012 Campus models they can easily be used on a non abs equipped Clio, they're bound to be cheaper because they're poverty spec so well worth trying to find
ex-Chinese Dave
I read about the ABS rings being on some parts and obviously they are not needed for a Cup. I'll stick with what i've got on for now and just clean up the disc surface a bit. Seems like genuine rear discs are easily available and cheaper if you don't look for specifically for a Cup part.
ex-Chinese Dave
Are the above n/s and o/s cables the correct length or do they need to be modified? I was told today that some aftermarket items are not the correct length.
MRBILLYUK
  FF Jeden Osiem Dwa
I have these exact cables fitted to my 182 and they're spot on 👍
It seems there quite a few variants for aftermarket handbrake cables and some are a got too long and some a bit too short.
