Clutch replaced but Immobiliser light solid and wont start, Help
Leo182
  Blk/Gld 182 Cupped
Any ideas? Garage has put a new clutch in, goes to start it, cranks but wont start red immobiliser light is solid, any ideas??
SharpyClio
Sorry, that would she’s helped. So there’s one strap in the end of the box that goes to the chassis.
For some reason I had it in my head this attached to the tie strap that’s a bit further back but I was wrong.
The other is on the back of the box, just up from where the near side driveshaft goes into the box. Easy to forget.
SharpyClio
Get him to double check all the wiring, its likely that something hasn't been reconnected properly, I did my clutch and gearbox last week and I am trying to remember all the things I disconnected. Some of them wouldn't cause an issue but some might, easiest way is to double check everything again, might even need to disconnect and reconnect things to try and make sure.
Leo182
  Blk/Gld 182 Cupped
Right, hes triple checked the earth straps and everything he says but still the same, he reckons its the immobiliser itself!
Hes at a loss, any ideas anyone?
Leo182
  Blk/Gld 182 Cupped
Ok, so I am getting a checklist of all possible issues in order to solve this and so far I have these.
1. Earths
2. Fuses/Relays
3. Crank Sensor bolt
4. New battery/2nd key fob
5. Broken wire.
Anything I've missed bearing in mind it was ok when it went in to have the new clutch fitted.
It does crank like I said but the immob light is solid.
Louis
I Love Ed Sheeran
Put the key in the ignition. Lock it and unlock it on the fob.
Lock it and unlock it on the button in the car.
Turn the key all the way round to just before cranking and leave it there for 5 minutes. Then go back, and do the same again but holding the central locking button.
Then try crank it.
Leo182
  Blk/Gld 182 Cupped
Update.
Mechanic has tried all the above and more, he's a decent guy been really good but this has him beaten, is there anything ANYTHING that I can try??
Its doing my head in tbh now, hes had it a week!
