Karcher hose reel
Gaz_
  Extreme mode
I'm wanting to keep my Karcher in the garage and basically have the high pressure hose on a reel to take out onto the drive
Looking for a reel and 15-20m of hose. I've seen some bits out there - kit wise they seem to be around £150 quid?
Anyone run anything similar?
npt
  BMW 320d- 172 cup
The one linked above was the only one I could see online, I'm looking to get one soon also fitted in the garage, such a chore fighting the standard plastic shyte
Cub.
I have a 25m one attached to the back of the house and bought this 50m for cleaning the cars / watering the far end of the garden;
Was on offer at £70 odd pound.
OEM Battery Nonce
Cub.
OEM Battery Nonce
I know he doesn’t want 50m, my point was, £150 sounds a lot for a 15-20m hose reel.
It’s still for sale at the same price;
Although it seems I’ve completely misread it and seen that he wants to leave the Karcher in the garage and use a long high pressure attachment. So I am still a berk.
Unsure why you want to do that though?
Hence my comment, had to double check I’d not read it wrong to avoid intense return fire.
I imagine it’s easier than lugging it out every time you want to use it, you can leave it plumbed in and plugged in and just pull the high pressure hose out.
Sir Nancy Flowers
  M140i
Just to stick my oar in here....
It all depends what you want. If you just want water access out in your driveway, as an example, then the hoselock reel that @Cub. linked should work a charm. Ive got one round the side of my house, for the garden that I never water...
However, if you want the ability to leave the Karcher in the garage and have pressurised water to wash the car with etc, then you'll need the directhoses £150+ jobby.
I do have that one too and its a game changer. Ive got their wall mounted pressure washer and reel. I flick the switch, pull the reel out and im cleaning. No lugging a big jetwash anywhere. Ive also hard mounted hot/cold water into the garage and have a switch based set up. Hot water jet washing in the winter is a game changer.
