Renault Clio 182 OEM Parts List
Mr Underhill
I’ll post this here since there’s no specific category for parts lists - I’ve asked about adding one but haven’t heard back yet.
Over my 8 years owning four Clio 182s and dealing with parts shortages, I’ve compiled a list of parts made by other manufacturers for Renault. Hopefully, this helps other 182 owners source parts when they’re no longer available (NLA) at your local Renault dealer. Each entry includes the Renault part number, the company that makes it, and their part number. Please add any other OEM parts you know about or correct anything that looks off! Caveat: Since compiling this list, some OEM parts may no longer be available.
Engine and Fuel System
1. Oil Filter
• Renault P/N: 8200768913
• Made by: Purflux
• OEM P/N: LS932
2. Air Filter
• Renault P/N: 8200459852
• Made by: Purflux
• OEM P/N: A1224
3. Cabin Filter (A/C)
• Renault P/N: 7711228912
• Made by: Purflux
• OEM P/N: AH143
4. Fuel Filter
• Renault P/N: 7700845961
• Made by: Purflux
• OEM P/N: EP210
5. Fuel Injectors
• Renault P/N: 8200207049
• Made by: Magneti Marelli
• OEM P/N: 805001446001 (IWP042)
6. Ignition Coil Pack
• Renault P/N: 8200141149
• Made by: Valeo
• OEM P/N: 245104
7. Lambda Oxygen Sensors
• Renault P/N: 7700107433
• Made by: Bosch
• OEM P/N: 0258006046
8. Spark Plugs
• Renault P/N: 8200239321
• Made by: NGK
• OEM P/N: PFR6E-10
9. Spark Plug Leads
• Renault P/N: 8200334440
• Made by: Beru
• OEM P/N: ZEF1144
10. Throttle Body
• Renault P/N: 8200110994
• Made by: VDO (Continental)
• OEM P/N: A2C59513667
11. Manifold Pressure Sensor (MAP Sensor)
• Renault P/N: 223650035R
• Made by: Continental/VDO
• OEM P/N: 5WK9681Z
12. Intake Temperature Sensor
• Renault P/N: 7700101451
• Made by: Lucas
• OEM P/N: SNB984
13. Camshaft Position Sensor
• Renault P/N: 8200789528
• Made by: Bosch
• OEM P/N: 0232101031
14. Crankshaft Position Sensor
• Renault P/N: 8200647554
• Made by: Bosch
• OEM P/N: 0986280408
Transmission
1. Clutch Kit
• Renault P/N: 7701476557 (or 7701475353)
• Made by: Valeo
• OEM P/N: 826558
2. Clutch Guide Tube
• Renault P/N: 8200128328
• Made by: Corteco
• OEM P/N: 49376781
Electrical
1. Alternator
• Renault P/N: 8200193100 (or 7711134267)
• Made by: Valeo
• OEM P/N: TG11C011
2. Starter Motor
• Renault P/N: 7711134301
• Made by: Valeo
• OEM P/N: D7R44
3. Front ABS Sensors
• Renault P/N: 8200186294
• Made by: Bosch
• OEM P/N: 0265007746
Brakes
1. Rear Brake Discs
• Renault P/N: 7701204901
• Made by: NTN-SNR
• OEM P/N: KF155.104U
2. Right Front Caliper
• Renault P/N: 7701205833
• Made by: TRW-Lucas
• OEM P/N: BHW242
3. Left Front Caliper
• Renault P/N: 7701205832
• OEM P/N: BHW241
4. Right Front Caliper Carrier
• Renault P/N: 7701047929
• OEM P/N: BDA492
5. Left Front Caliper Carrier
• Renault P/N: 7701047928
• OEM P/N: BDA491
6. Front Brake Pads
• Renault P/N: 7701207066
• Made by: Ferodo
• OEM P/N: FDB1393
Cooling and A/C
1. A/C Condenser
• Renault P/N: 7700414103
• Made by: Denso
• OEM P/N: DCN23006
2. A/C Dryer
• Renault P/N: 7700836314
• Made by: Denso
• OEM P/N: DFD23007
3. Radiator
• Renault P/N: 7700417175
• Made by: Denso
• OEM P/N: DRM23011
4. Cooling Fan
• Renault P/N: 7701070217
• Made by: Denso
• OEM P/N: DER23003
5. A/C Compressor
• Renault P/N: 6000073500 (SD6V12GE1422)
• Made by: Denso
• OEM P/N: DCP23059
6. A/C Pressure Sensor
• Renault P/N: 7701205751
• Made by: Denso
• OEM P/N: DPS23010
7. A/C Expansion Valve
• Renault P/N: 7701206357
• Made by: Valeo-Denso
• OEM P/N: DVE23004
8. Water Pump
• Renault P/N: 7701476496
• Made by: SKF
• OEM P/N: VKPC 86415
Belts and Pulleys
1. Auxiliary Tensioner Pulley
• Renault P/N: 8200429703
• Made by: Hutchinson
• OEM P/N: 315975058744
2. Guide Pulley
• Renault P/N: 8200065479
• Made by: SKF
• OEM P/N: VKM 36016
3. Auxiliary Belt Kit
• Renault P/N: 7701477519
• Made by: SKF
• OEM P/N: VKMA 36070
4. Timing Belt Kit
• Renault P/N: 7701476675 (Phase 2)
• Made by: Gates
• OEM P/N: K015509XS
Suspension and Steering
1. Wheel Bearings (Front)
• Renault P/N: 7701205779
• Made by: NTN-SNR
• OEM P/N: R155.75
2. Power Steering Pump
• Renault P/N: 8200234212
• Made by: TRW
• OEM P/N: JPR268
3. Front Shock Absorbers (Non-Cup, 54mm Bolt Spacing)
• Renault P/N: 8200681106
• Made by: Monroe
• OEM P/N: G7203
4. Front Shock Absorbers (Cup, 60mm Bolt Spacing)
• Renault P/N: 8200681109
• Made by: Monroe
• OEM P/N: G7203
5. Rear Shock Absorbers (Non-Cup)
• Renault P/N: 8200681131
• Made by: Monroe
• OEM P/N: G1049
6. Rear Shock Absorbers (Cup)
• Renault P/N: 8200681125
• Made by: Monroe
• OEM P/N: G1049
16v_paddy
  Valvers & 172 Cup
How sure are you about the shock absorbers? Only ask as I'm having extreme difficulty finding pattern part shocks for normal 172 atm
Mr Underhill
The OEM for the 172 cup shocks was KYB
Cheers @Krarl Thanks for the 172 Cup info.
I’m focusing on the 182, and when I replaced my Cup shocks in 2017, they had Monroe markings. That doesn’t prove Renault used Monroe as the OEM, but it proves they supplied a shock absorber and aligns with sources that I checked at Renault Parts Direct, K-Tec Racing, and AutoDoc at the time. I also checked Monroe catalogues (part numbers matched up) and I wrote them all in a spreadsheet like the saddo I am 🤣 I got my replacements from RPD anyway.
I haven’t found any evidence that KYB supplied shocks for the 182 though. But if you know any 182 owners who’ve seen KYB markings on their shocks, it would help refine the list! 😊
mumpy
  Clio II RS 172
What is the aftermarket go to for 172 cup front shocks (8200681108). Not able to find something at the moment, sadly :(
Mr Underhill
I think KONI offers an alternative – 8710-1395SPORT. I'm not sure if they specifically cater to the CUP versions, though, which I imagine would be more road-compliant, with the KONI being more performance-oriented. Was there much difference between the standard strut and the CUP versions back in the day?
I'm only familiar with the 182 Cup-packed cars, to be honest. I wouldn't want to send you on a wild goose chase. As far as I can tell, KONI only lists one option.
MRBILLYUK
  FF Jeden Osiem Dwa
Thanks for posting all that info 👍
Just a couple of questions.
It says the front shock absorber 54mm and 60mm bolt spacing have the same Monroe part number G7203?
Likewise the rear shock absorber for cup and none cup. G1049?
Mr Underhill
Yes, I noticed the mistake after posting—it was my error. When I checked with Monroe, the number had disappeared, which is why I mentioned that some parts are no longer in production since I compiled the list. I guess this is one of those cases. I should have been more careful, but the list is eight years old! 🤣 It was a cut-and-paste job.
If you find the correct information, feel free to update the thread. I think it’s worth doing given the number of messages I’ve received 🙈
16v_paddy
  Valvers & 172 Cup
As mentioned above, the only thing I can find are the Koni's as well but they're about £200 each, it's not so bad if you're not having to by springs but you're then into similar money as coilovers
Mr Underhill
I heard that Kam Racing may be making their own front cup shocks for the 172 in the future, so there is hope!
I know Grams are making the 182 Cup Springs. I have a brand new set here, which look identical and still have the Renault part number. I’ll be fitting them in the summer, so will feedback. Hopefully, more companies will get on board as there’s still a market, I’m sure 🤞🏻
MRBILLYUK
  FF Jeden Osiem Dwa
I was on holiday at the time so couldn't check what I had at home.
These are genuine Renault 182 front and rear cup shocks that I bought from RPD a few weeks ago.
I couldn't see any indication that they're made by Monroe.
All 4 boxes say they're made in Spain.
Maybe Renault had more than one supplier?
MRBILLYUK
  FF Jeden Osiem Dwa
I've been running Grams springs on my 182 for a couple of years now and really rate them.
Tony_HH
1. Oil Filter
• Made by: Purflux
• OEM P/N: LS932
2. Air Filter
• Made by: Purflux
• OEM P/N: A1224
• Made by: Purflux
• OEM P/N: AH143
4. Fuel Filter
• Made by: Purflux
• OEM P/N: EP210
5. Fuel Injectors
• Made by: Valeo
• OEM P/N: 245104
• Made by: Bosch
8. Spark Plugs
• Made by: NGK
• OEM P/N: PFR6E-10
9. Spark Plug Leads
• Made by: Beru
• OEM P/N: ZEF1144
10. Throttle Body
• OEM P/N: 5WK9681Z
• Made by: Lucas
• OEM P/N: SNB984
• Made by: Bosch
• Made by: Bosch
Transmission
1. Clutch Kit
• Made by: Valeo
• OEM P/N: 826558
• Made by: Corteco
• OEM P/N: 49376781
Electrical
1. Alternator
• Made by: Valeo
• OEM P/N: TG11C011
2. Starter Motor
• Made by: Valeo
• OEM P/N: D7R44
• Made by: Bosch
Brakes
1. Rear Brake Discs
• Made by: NTN-SNR
• OEM P/N: BHW242
• OEM P/N: BHW241
• OEM P/N: BDA492
• OEM P/N: BDA491
6. Front Brake Pads
• Made by: Ferodo
• OEM P/N: FDB1393
Cooling and A/C
1. A/C Condenser
• Made by: Denso
• OEM P/N: DCN23006
2. A/C Dryer
• Made by: Denso
• OEM P/N: DFD23007
3. Radiator
• Made by: Denso
• OEM P/N: DRM23011
4. Cooling Fan
• Made by: Denso
• OEM P/N: DER23003
5. A/C Compressor
• Made by: Denso
• OEM P/N: DCP23059
• Made by: Denso
• OEM P/N: DPS23010
• OEM P/N: DVE23004
8. Water Pump
• Made by: SKF
Belts and Pulleys
2. Guide Pulley
• Made by: SKF
• Made by: SKF
4. Timing Belt Kit
• Made by: Gates
• Made by: NTN-SNR
• OEM P/N: R155.75
• Made by: TRW
• OEM P/N: JPR268
• Made by: Monroe
• OEM P/N: G7203
• Made by: Monroe
• OEM P/N: G7203
• Made by: Monroe
• OEM P/N: G1049
• Made by: Monroe
• OEM P/N: G1049
Hi, do you know the part number of the NS “passenger side”steering knuckle for 182 cup by any chance? My mate is sourcing the part but has extremely limited information from the internet
