Willo40
M135i
Might be a good option for @SharkyUK
The issue for AMD is that people buy Nvidia products whether they're better or not, because Nvidia. So they don't get the revenue to fund the top tier.Well, a major workstation upgrade is on the cards this year... assuming I can get hold of my ordered 5090! I'm alright for PSU, case, cooling, cabling, and storage. But I will need a new CPU, mobo, and RAM. Thanks both for the link and mention. However, without wanting to sound like an ungrateful pr!ck, it's not a high enough baseline spec for what I'm wanting/needing. Ideally, I want to go with a HEDT CPU again and a mobo that has additional PCI-E lanes, and support for 192GB RAM. I'm not sure whether to go Team Blue or Team Red with the CPU, whilst the GPU is Team Green. It's a shame AMD aren't pursuing that top tier of the GPU market.
I also often see the reason "bEcAuSe aMd DrIvErS aRe BaD"...yeah about 25 years ago. Over the past few years I've personally had more issues with Nvidia drivers than AMD.
I'm a bit out of touch of late. Ouch!I'm not sure how closely you follow Team Green, but the latest run of drivers supporting 50x0 have been one trainwreck after another, and it's also affected older series cars as nVidia try to fix the numerous issues that are surfacing. aMd DrIvErS wOrK bEsTeReR rIgHt NoW.
EDIT: In fact, I think AMD drivers would probably work better powering nVidia hardware right now. 🤣
Did you manage to get a 5090 in the end, Andy?
Overclockers have had loads of Astrals to buy "off the shelf" a few times over the last few weeks.No mate, it will be 3 months of waiting in a few days time. And I was a "lucky" one who got a day one pre-order.
I've still got 131 people in front of me and that queue position number drops by about 3 or 4 a week (on a good week). Scan were happy to take my 3k immediately, of course... and have been sitting on that money. I can get a refund, but I then lose my position in the queue. It's an absolute farce. By the time I get the GPU, I'll be putting in the order for the 6090.![]()
Ooh, a big delivery of stock hit Scan today and I've gone from queue position 131 to 109. 🤣 You see? This is what it's brought me to!
I haven't paid any attention at all to the 50 series cards. Why are they so unavailable? Scalpers and miners? I wouldn't have thought a £3k card would be that popular really
Have they sorted the heat issues out with the 5090s?
Threw together some old parts and helped my daughter build her first PC. Nothing too special, just a de-lidded 4790k @4.8GHz and a GTX 1080 that's had the thermal paste replaced with liquid metal. Paired with a 32" 75Hz 1440p monitor Good enough for Minecraft etc.
Turns out it's the perfect use case for modern AI stuff too. Installed Hogwarts Legacy and as expected it was a stuttering mess, but after some tweaking with Optiscaler it's now running on high settings at 1440p at a locked 75fps using a combination of FSR 3 quality mode which gets the base framerate to 60+fps, then FSR 3.1 frame gen to smooth out stutters. It's a genuinely good gaming experience despite being 10 year old hardware. I'm shocked 😯
I bet he uses an OG Xbox controller too because his paws are too big for human sized controllersNice one!
Starting them young on mouse and keyboard ftw. Come to it too late and they end up crippled like @Cub. 🤡🎮
I never realised they had all that on them. Probably cheaper than replacement under warranty 🙈The reason I am holding out for the ROG Astral OC is for the clever gubbins built into it. It has load sensors on each wire from the power connector and can report current load on them individually, shutting down the GPU if necessary. It also has a built-in gyroscope that reports back excessive sag that can lead to uneven pressure on the PCIe connector.
OCUK had more in stock this week also. LC and air.Ooh, a big delivery of stock hit Scan today and I've gone from queue position 131 to 109. 🤣 You see? This is what it's brought me to!
