182 Trophy- Rattle after timing belt change
  Clio Trophy
Picked the car up yesterday after getting the timing belt and a load of work done and there's an obvious rattle coming from it now, almost sounds like something's loose to me-
That sound like anything in particular to anyone's ears? I noticed something within about 10 mins of driving away but didn't know what it was related to and I'd travelled 2 hours to pick it up after a month so wasn't inclined to turn back on a Saturday!
Seems most obvious in the second video around 1500rpm. I’ve already checked the fuel rail guard is tight.
  Clio Trophy
Also, I had most of the front suspension replaced and steering rack bushes changed so the subframe was dropped. Hopefully it might be a heat shield as has been suggested on the Clio Trophy forum.
mumpy
  Clio 172, WRX STI
If you get out of the car can you check whether the sound is coming from engine bay or underneath the car? With the engine off, let it cool down and poke all the heat shields one by one (including exhaust mani heat shield) until you find which one it is. Vibration is higher at lower rpm so it would make sense that you only hear it near idle.
  Clio Trophy
I had already checked the fuel rail guard and there's no movement in it.
Very hard to determine exactly where it's coming from whether I listen at the engine bay or on the ground to the side of the car.
On it potentially being a heat shield- would it be normal for when this occurs to change depending on temperature etc.? Today it doesn't seem to be doing it much at idle as in the videos but was more noticeable when accelerating around town between ~2000-3000rpm.
mumpy
  Clio 172, WRX STI
Yes it can happen I guess, temperature can affect the resonant frequency etc. so it could still be the heat shields or exhaust bracket etc.
Jamie
  Audi B8.5 RS4 & 200
It’s making quite a noise, so tracing shouldn’t be difficult. Can’t you just jack it up on axle stands and have someone rev it for you?
