The Power PC Thread [f*ck off consoles]
Yeah thanks, I’m set now on the 9070xt, need to save up and spend the extra on it, is there a certain one I should look out for . Not clued up on the names either nvidia and amd.
also I’m looking at having a duel monitor set up for my new system soon, need a new 2nd monitor . Is it simple to set up with the say 9070xt and 2 monitors? is the power from the gpu from 2 monitors minimal?
Sapphire, XFX, Powercolor, ASUS
Go with the fastest one out of the box at the best price. They're all much of a muchness.
Does it stop if you stop any of the fans spinning? Kinda sounds like something is hitting one
As @Cookie said, that sounds exactly like something hitting one of the fans.
Cheers lads, is this the CPU cooling fans I'm assuming? I would have thought if that were the case, it would be happening consistently, no?
I took them off for a dust up a few weeks back. No change.
The next time it happens I'll reposition them and see if that helps. Hard to see what's coming into contact with the fans though as they're in a concealed (ish) unit.
I'm a bit more clued up than before with the GFX, thanks for that. I'm in need of a new PSU , I'm leaning towards the Corsair RM750e , there's 2 versions i've been looking at the 2023 and the 2025 model, I've done a bit of research and there's mention about a noise coming from some, not sure if this is nothign to worry about or is there more to it?
Depends on the noise. Might just be coil whine.
Have a look at Fractal, Asus and Seasonic PSUs too. They're all pretty much as good as each other.
Make sure it's modular, makes cabling easier. And mesh sleeved cables are a bit nicer looking too.
Find reviews on fan noise if that's something that bothers you. But generally they're all quiet.
what about this one?
I finally placed an order today on the Ryzen 9700x of Amazon, it dropped in price @ £260. I’m hoping it’s genuine. Be big improvement going from a intel i5-6600
That’s quite the jump! I’ve still got my old 6700k sat around in a spare PC, can’t bring myself to get rid of it.
@Daz... Not sure what to do with the parts , keep them or destroy them or what? Been a great pc for the last 9 to 10 years now. Got a local company helping me build my new one which is good, still need some parts. Need to get software too Microsoft and Office
Windows and office will set you back about £40-50 for both,either through somewhere like G2A or sometimes on Groupon
Has nobody else played Clair Obscur? It's one of the best gaming experiences I've ever had in my life.
Looks really good, but looks like it's a button bashing fest?
Not at all mate. Turned based combat with quick time events, has a parry and a dodge system which is excellent. But it's all about the story, oh my. It's a plot that Christopher Nolan would be proud of and an OST that Hans Zimmer would approve (I'd go as far to say it's the best OST of all time in a video game, honestly).
The game has left me broken and I need something to fill the void!
It looks pretty amazing mate.
Comfortably in my top 5 of all time :)
It's currently the highest rated Metacritc game of all time too, based on user reviews. It's a genuine masterpiece.
EDIT: Oh, and the lead writer was just someone they got from Reddit and the main composer they found on Soundcloud :ROFLMAO:
there was a thread on this and someone mentioned Gamers Outlet, going to order on those soon for both around £20
What's all of your fan controller of choice? I want to stay away from corsair iCue, am looking at an NZXT 280mm and apart from the lcd display no other rgb.
I just use the fan control in the motherboard BIOS. Very easy to setup. Tweak it to how you want it then literally forget about it ever again.
That's the one I use. Nice too
Have used although had problems when I put a new corsair water cooler and ended up just sticking with icue. I dont want rgb or anything unnecessary with my new workstation build so hopefully with something like the NZXT setup fancontrol is all good.
@N0ddie If I can setup something in bios I think I will, the problem I had a while back was the fans were on high and the cpu temps were high, I set fancontrol and cpu temps were low and fan speeds low. Like in bios the cpu temps would slowly increase even with fans high.
Make sure you have the pump speed set correctly, running it at full speed isn’t the most efficient way of cooling.
I always found having the pump set at 60-65% worked best.
I have an NZXT case and liquid cooler which displays temps, and use NZXT to control the fans and RGB's, work fine for me, leave it on automatic and it does it thing, don't have to worry about it, and the fans are pretty quiet.
I didn’t know nzxt had their own software! Makes things easier..
I’m also making a modified fractal terra case to fit a 280mm aio, pictures of cad model to follow..
I'm thinking of moving on my PC as it hasn't been switched on this year! I have no idea what to price it at, and would ideally like to sell it as a complete unit. Anyone got any ideas what I should put it up for?
Spec:
  • Asus ROG Crosshair X670E Hero (Socket AM5) DDR5 ATX Motherboard
  • AMD Ryzen 9 7950X Sixteen Core 5.70GHz (Socket AM5) Processor - Retail
  • Corsair Dominator Platinum RGB EXPO 32GB (2X16GB) DDR5 PC5-48000C36 6000MHz Dual Channel Kit - Black (CMT32GX5M2D6000Z36)
  • Gigabyte AORUS GeForce RTX 4090 MASTER 24GB GDDR6X PCI-Express Graphics Card
  • Corsair AXi Series AX1600i 1600W 80 Plus Titanium Digital Modular Power Supply (CP-9020087-UK)
  • NZXT Kraken Z73 RGB AIO CPU Water Cooler with LCD Screen - 360mm
  • Samsung 1TB 870 QVO SSD 2.5" SATA 6Gbps 64 Layer 3D
  • Samsung 970 EVO Plus 500GB M.2 2280 PCI-e 3.0 x4 NVME
  • Corsair iCUE 7000X RGB Tempered Case
I’d break it for parts. Sell the mobo, CPU, memory and cooler as a one-stop upgrade package that someone can just bolt straight in. The 4090 is still a killer card so should sell very well.
My experience is that selling whole PCs is less hassle, but also surprisingly difficult and you get less than you would by selling the parts.
Yeh I’ve heard that from a few other people now, just more hassle!!
Rumours are circulating that the SUPER's are making a return for the 50 series.
Is around now the best time to get a RX 9070XT. Seen the ASUS TUF at just under £700. And the other ones around £600 or more like the Prime and Pulse. Is it better to have DP over HDMI or it, or does it not matter, some have 3 DP and 1 HDMI that’s all and some have 3 HDMI and 1 DP
Spec:
If you do decide to sell and have a price in mind PM please mate.
