The Power PC Thread [f*ck off consoles]
Grandpa Joe
Yeah thanks, I’m set now on the 9070xt, need to save up and spend the extra on it, is there a certain one I should look out for . Not clued up on the names either nvidia and amd.
also I’m looking at having a duel monitor set up for my new system soon, need a new 2nd monitor . Is it simple to set up with the say 9070xt and 2 monitors? is the power from the gpu from 2 monitors minimal?
Sapphire, XFX, Powercolor, ASUS
Go with the fastest one out of the box at the best price. They're all much of a muchness.
Ray Gin
  Cupra Leon & Impreza
Does it stop if you stop any of the fans spinning? Kinda sounds like something is hitting one
As @Cookie said, that sounds exactly like something hitting one of the fans.
Cheers lads, is this the CPU cooling fans I'm assuming? I would have thought if that were the case, it would be happening consistently, no?
I took them off for a dust up a few weeks back. No change.
The next time it happens I'll reposition them and see if that helps. Hard to see what's coming into contact with the fans though as they're in a concealed (ish) unit.
Geddes
  Fiesta Mk8 ST-3
I'm a bit more clued up than before with the GFX, thanks for that. I'm in need of a new PSU , I'm leaning towards the Corsair RM750e , there's 2 versions i've been looking at the 2023 and the 2025 model, I've done a bit of research and there's mention about a noise coming from some, not sure if this is nothign to worry about or is there more to it?
Grandpa Joe
Depends on the noise. Might just be coil whine.
Have a look at Fractal, Asus and Seasonic PSUs too. They're all pretty much as good as each other.
Make sure it's modular, makes cabling easier. And mesh sleeved cables are a bit nicer looking too.
Find reviews on fan noise if that's something that bothers you. But generally they're all quiet.
Geddes
  Fiesta Mk8 ST-3
Daz...
  Inferno 182 Cup
I finally placed an order today on the Ryzen 9700x of Amazon, it dropped in price @ £260. I’m hoping it’s genuine. Be big improvement going from a intel i5-6600
That’s quite the jump! I’ve still got my old 6700k sat around in a spare PC, can’t bring myself to get rid of it.
Geddes
  Fiesta Mk8 ST-3
@Daz... Not sure what to do with the parts , keep them or destroy them or what? Been a great pc for the last 9 to 10 years now. Got a local company helping me build my new one which is good, still need some parts. Need to get software too Microsoft and Office
Grandpa Joe
Windows and office will set you back about £40-50 for both,either through somewhere like G2A or sometimes on Groupon
Wilkeh
  MK4 Anni & MK5 Edt30
Looks really good, but looks like it's a button bashing fest?
Not at all mate. Turned based combat with quick time events, has a parry and a dodge system which is excellent. But it's all about the story, oh my. It's a plot that Christopher Nolan would be proud of and an OST that Hans Zimmer would approve (I'd go as far to say it's the best OST of all time in a video game, honestly).
The game has left me broken and I need something to fill the void!
Willo40
  M135i
It looks pretty amazing mate.
Wilkeh
Comfortably in my top 5 of all time :)
It's currently the highest rated Metacritc game of all time too, based on user reviews. It's a genuine masterpiece.
EDIT: Oh, and the lead writer was just someone they got from Reddit and the main composer they found on Soundcloud :ROFLMAO:
GiT
  Shit little Yaris...
N0ddie
  Tesla Model 3
I just use the fan control in the motherboard BIOS. Very easy to setup. Tweak it to how you want it then literally forget about it ever again.
Beauvais Motorsport
That's the one I use. Nice too
Have used although had problems when I put a new corsair water cooler and ended up just sticking with icue. I dont want rgb or anything unnecessary with my new workstation build so hopefully with something like the NZXT setup fancontrol is all good.
@N0ddie If I can setup something in bios I think I will, the problem I had a while back was the fans were on high and the cpu temps were high, I set fancontrol and cpu temps were low and fan speeds low. Like in bios the cpu temps would slowly increase even with fans high.
Daz...
  Inferno 182 Cup
Make sure you have the pump speed set correctly, running it at full speed isn’t the most efficient way of cooling.
I always found having the pump set at 60-65% worked best.
Oggy997
  997.1, Caddy, e208
there was a thread on this and someone mentioned Gamers Outlet, going to order on those soon for both around £20
Willo40
  M135i
What's all of your fan controller of choice? I want to stay away from corsair iCue, am looking at an NZXT 280mm and apart from the lcd display no other rgb.
I have an NZXT case and liquid cooler which displays temps, and use NZXT to control the fans and RGB's, work fine for me, leave it on automatic and it does it thing, don't have to worry about it, and the fans are pretty quiet.
