MarkCup
Free to use on the day, or unceremoniously dump all your gear into if they're all taken by the time you arrive/rise.
Just don't be that c**t that leaves their car in a garage all morning when they've only booked an afternoon slot
There was one weapons grade ballbag that did that last year
Ahem! I’m on all day nowI need a new garage friend seeing as though Dan is being a wuppytupper and not bringing the MK1
Not the M2?I think I've broken my car 😢. I'm definitely not going to be confident taking whatever I turn up in on track so how do I recycle my afternoon session? @Nik @Sunglasses_Ron
Can't remember, when we booked the track time did we have to specify a car? If we're bringing a different one than originally intended, does anyone need to be notified?
mine getting mapped on the 26th so won't be ready, same question as above
😭😭😭😭😭Not the M2?
What’s it doing or not doing?😭😭😭😭😭
It's not going in straight lines and under hard acceleration it's down right impossible to keep it aiming straight. I had new tyres fitted last week and a new track rod end so they either didn't align it right or left something loose or something has broke. I've not got a lot of spare time to get it looked at and I really don't want to test the wall at Anglesey 😂.What’s it doing or not doing?
Get it to chongIt's not going in straight lines and under hard acceleration it's down right impossible to keep it aiming straight. I had new tyres fitted last week and a new track rod end so they either didn't align it right or left something loose or something has broke. I've not got a lot of spare time to get it looked at and I really don't want to test the wall at Anglesey 😂.
Goigled him and now I'm on a government watch list, what's the company called?Get it to chong
ATEC ALIGN BEBBY.Goigled him and now I'm on a government watch list, what's the company called?
Right ok. Multitude of potential issues there then. They could’ve fucked the rear toe adjusters.It's not going in straight lines and under hard acceleration it's down right impossible to keep it aiming straight. I had new tyres fitted last week and a new track rod end so they either didn't align it right or left something loose or something has broke. I've not got a lot of spare time to get it looked at and I really don't want to test the wall at Anglesey 😂.
Sounds painful 😣. So start with a decent alignment check then?Right ok. Multitude of potential issues there then. They could’ve fucked the rear toe adjusters.
My car doesn't have a f**king gearbox in it and my tow car has just been dropped off for new turbos and mappingIt's not going in straight lines and under hard acceleration it's down right impossible to keep it aiming straight. I had new tyres fitted last week and a new track rod end so they either didn't align it right or left something loose or something has broke. I've not got a lot of spare time to get it looked at and I really don't want to test the wall at Anglesey 😂.
Needs a good visual inspection first to see if they’ve fucked something, or left something loose.Sounds painful 😣. So start with a decent alignment check then?
I had a set of conti sport 7 fitted. It's a lot faster now it has some grip but under full throttle it's like driving a jelly.Needs a good visual inspection first to see if they’ve fucked something, or left something loose.
Wouldn’t be the first time I’ve seen the rear toe arms left loose either, as access isn’t amazing to tighten them up properly.
What tyres you running? I drove another M2 comp at work today, and it was running the mpss. Mines on ps4s and it drives completely different by comparison, and in a positive way too.
Shush. I spent half an hour swearing at the twingo yesterday and my spine is fucked. I'm too old for this s**t so my clio will probably never see the road again 😂.My car doesn't have a f**king gearbox in it and my tow car has just been dropped off for new turbos and mapping
Pull your finger out
Lol yeah MPSS are s**t in every way, unless they’re absolutely red hot 😂I had a set of conti sport 7 fitted. It's a lot faster now it has some grip but under full throttle it's like driving a jelly.
I should probably try driving it without the radio on and listen for any noises and then look for anything loose. f**king cars suck.Lol yeah MPSS are s**t in every way, unless they’re absolutely red hot 😂
Any noise from the rear end? Rear diff bush is a common area. You could put a diff lift kit on it and then listen to the diff whining its tits off lol
Tbf I think you’d feel it through the car if the diff bush was giving it some, but it’s worth trying to see if you can hear owt.I should probably try driving it without the radio on and listen for any noises and then look for anything loose. f**king cars suck.
