CSF25 ClioSport Festival 2025
charltjr
Can't remember, when we booked the track time did we have to specify a car? If we're bringing a different one than originally intended, does anyone need to be notified?
Sunglasses_Ron
ClioSport Admin
PM @Nik
I think I've broken my car 😢. I'm definitely not going to be confident taking whatever I turn up in on track so how do I recycle my afternoon session? @Nik @Sunglasses_Ron
PM @Nik
mine getting mapped on the 26th so won't be ready, same question as above
PM @Nik
Sorry @Nik
Just bear in mind that he’s a busy bloke. But he will get back to you x
Clio_fool
What’s it doing or not doing?
It's not going in straight lines and under hard acceleration it's down right impossible to keep it aiming straight. I had new tyres fitted last week and a new track rod end so they either didn't align it right or left something loose or something has broke. I've not got a lot of spare time to get it looked at and I really don't want to test the wall at Anglesey 😂.
Louis
I Love Ed Sheeran
Get it to chong
NorthloopCup
Right ok. Multitude of potential issues there then. They could’ve fucked the rear toe adjusters.
Klumpy Dumpy
My car doesn't have a f**king gearbox in it and my tow car has just been dropped off for new turbos and mapping
Pull your finger out
NorthloopCup
Sounds painful 😣. So start with a decent alignment check then?
Needs a good visual inspection first to see if they’ve fucked something, or left something loose.
Wouldn’t be the first time I’ve seen the rear toe arms left loose either, as access isn’t amazing to tighten them up properly.
What tyres you running? I drove another M2 comp at work today, and it was running the mpss. Mines on ps4s and it drives completely different by comparison, and in a positive way too.
Clio_fool
I had a set of conti sport 7 fitted. It's a lot faster now it has some grip but under full throttle it's like driving a jelly.
NorthloopCup
Lol yeah MPSS are s**t in every way, unless they’re absolutely red hot 😂
Any noise from the rear end? Rear diff bush is a common area. You could put a diff lift kit on it and then listen to the diff whining its tits off lol
Clio_fool
I should probably try driving it without the radio on and listen for any noises and then look for anything loose. f**king cars suck.
