Recommend a clip/coding setup
Polynesian
  Alpina B3, 172, 325i
In short I just want to be able to read codes, diagnose things effectively, and switch off airbag lights etc- something that has some effective power but isn’t too expensive. Any recommendations? Have looked at foxwell NT604, is there a Clip setup that is straightforward to use?
Or anyone near SE London/ Kent/Essex who can do this stuff?
hopgop1
I always rated my RSTuner, can get an additional module for the airbag ECU to code that, plus it's relatively idiot friendly unlike Clip I believe, plus I think you need a laptop on an old version of Windows to run what you need for a mk2? Gives you far better codes to read than a generic reader, but it doesn't go as in depth in terms of the diag tests you can do with Clip.
Brigsy
  T.Turbo
I prefer clip for mk2 personally as it gives you the exact data on the dtc.
Cant go wrong with Renolink, however its mostly short hand french so need to be a bit careful on what your doing and dtc data can be a bit thin.
Rst is also good, but costs a small fortune in modules.
Mbeau
  Clio 172
I am South London mate and can code airbag lights and read ECU on the 172/182.
