The Power PC Thread [f*ck off consoles]
6700k is probably a smidgen younger.
it quite comfortably hits 60-70fps on a 21:9 on max settings.
i'm just finding it hard to justify the upgrade just for iracing
With my previous 6700K - I went from a GTX1080 which was a good combo in terms of balance @1440.
Then, I upgraded the GPU to an RTX3070Ti and it absolutely battered the CPU. It simply couldn't keep up and the cooling for the CPU was way more active than previous.
Ended up going down the Ryzen route and normality resumed.
I ended up with a ryzen 7 9800x and rx6900xt lc combo
Gone from an average of 60fps 1440 at medium to 120-200 1440 at ultra
It’s made worlds of difference especially with 40+ cars on the grid
Is that the 9800X3D? Makes a big difference on games that can utilise the v-cache onboard the CPU.
Thanks @Ray Gin
Currently waiting for the 9070 from Gotraka which I ordered the other day. But will bare these in mind if that falls through 👍
Just ordered a Deathadder mouse, any recommendations on a reasonably priced keyboard (around £50) just to get me started.
Jesus have you seen the price of RAM? I paid £230 for 64GB DDR5 C30 and the same one is now £800 :oops:
I saw some crazy prices being banded about and the 32GB kit I have is now £350 when I paid £100 just over a year ago.
Yup, and it is going to get worse due to forecast shortages. 😪 I did have a 192GB RAM kit lined up but that isn't happening now. I am due a full system upgrade (other than GPU) but the cost is eye watering at the moment.
The prices of the ram has gone up past weeks or something. It’s been mentioned about prices going up on other hardware too.
If anyone sees a good deal on a 5090 / 9800x3d build hook a brother up. I’ve seen some at around £3400. I take it ill not find many deals cheaper?
What’s causing the shortage?
AI - running large models takes s**t-tons of RAM plus devices need more onboard memory to run their AI features without going to their data connection for everything. Then you’ve got the push for graphics cards to have more memory as standard. All of this takes capacity away from conventional DRAM production as they switch to producing the very high bandwidth stuff that AI demands.
The producers aren’t massively ramping production in response because a) they are making a f**k-ton more money per unit, b) they don’t want to be caught out when the bubble bursts and c) it’s just not there without building more factories which takes time (see also point b)
It’s like Covid all over again.
Pre-builts will be the cheaper way to get parts…for now.
So much this. During the GPU shortages I bought a few prebuilts and turned a decent profit on them.
I mean, this is a lot of money but it’s got £700 worth of memory, a £2100 GPU, £500 CPU and by the time you factor in SSD, PSU, Case and motherboard…
I know, Alienware, yuck. But the new Area 51 is actually decent.
Surely you can’t turn a profit on the above.
That seems like quite a big PSU no? I’ve seen 5090/9800x3d builds with 1000W.
I would recommend 1200W at least if you are running the 5090 and a higher end CPU. You need clean power headroom that is not running at close to it's 100% limit under heavy loads. 1000W is a bit too low in my opinion, as ridiculous as that sounds. The 5090 can pull 500-600W, a heavy load on the CPU can see 250W, and then you have the draw from other components.
Oh god no, we’re not at GPU insanity levels or anything. My bad for mentioning what I used to do alongside an example of the point I was
trying to make, which was how if you can get a good spec prebuilt with plenty of RAM at a decent price then you can’t build it yourself for less at the moment.
Andy, out of interest have you tried to work out how much an hour your PC costs to run? just curious.
I tried to put together some rough "finger in the air" costs (for my business use vs. personal use) but I am not really sure how accurate they are! I think light loads and general low use was about 4p an hour and heaviest use was about 28p an hour. Most of the time, the PC is not under heavy use though of course. Unless I am playing Cyberpunk with ultra graphics and path tracing on! 😂 It pulls as much power as some heavy workloads. 🤪
Question for the PC nerds. When I exit a game sometimes my PC automatically restarts and I dont know why. Anyone got any ideas? Tbf I could probably do a full reset and reinstall of windows for a system refresh but I just CBA getting round to that unless I have to.
:unsure:
  1. Does it reboot instantly, or show a blue screen?
  2. Does it happen with all games or just one?
  3. CPU model, GPU model + PSU model/wattage?
  4. Any overclocks or XMP enabled?
  5. Does Event Viewer show anything useful?
:unsure:
Okay so..
1. Pretty much yeah freezes up a bit and then restarts no blue screen or anything
2. I've literally only played arc raiders over the last few weeks but I'm sure it happened before with BF6. Usually after a long sesh.
3. Pretty much this build so Ram is pretty low but generally been okay for years now.
4. Yep xmp enabled but that's all I've done. Not any proper overclocking.
5. I'll have a to figure out how to check that 😂
I did a while back now turn the fans down because they get annoying although should be at 100% anything over 75-80c. Maybe that's my first go to try and resolve also will look at event viewer and see if there's anything obvious.
